Mudi v2 eSIM MatchingID is refused
I have Mudi v2 and recently I bought EIOTCLUB physical eSIM. I tried with several eSIMs and I have problem with one eSIM from polish telecom Orange. I got following error message:
Device start connect internet
Internet connect success
Device start download profile
Download profile: 40%
Download profile fail: maybe this profile has been downloaded repeatedly by other devices or the current device, please check it or use other esim profile to test, if you confirm this is first time download, you can copy this logs to contact GL.iNet support get help.
Err message:Auth client fail. | {"header":{"functionExecutionStatus":{"status":"Failed","statusCodeData":{"subjectCode":"8.2.6","reasonCode":"3.8","message":"MatchingID is refused"}}}}
Do you know how to deal with it? Maybe EIOTCLUB eSIMs are buggy or something like that?
The eSIM I try to install is brand new, freshly generated and never used before.
It appears that your polish telecom Orange esim can only be installed/activated on devices with a specific EID. It's not compatible with the EIOTCLUB eSIM card
@Cathy
Is there any list of supported EIDs? Can I change the EID?
There is also Simpoyo eSIM. Is it better than EIOTCLUB eSIM?
Sorry the EID is the unique ID for the physical esim card and cannot be changed.This EID blacklist is a restriction from the eSIM provider, so it's advised to contact polish telecom Orange for further support
