I have upgraded to the latest 4.3.19 firmware but I do not see an eSIM option on the UI. Can someone provide guidance please?
I was just going to post this as well. I have V2 as well, latest firmware, esim page not showing up.
Hi,all!
Latest firmware with esim function for Mudi v2 is 4.3.21_beta1.
You can download from address:GL.iNet download center
installed the beta firmware , and the esim page still not showing up
Did you insert the physical eSIM?
Can you execute a command in background via ssh and post the result?
here is the command:
curl -s -X POST -H 'Content-Type: application/json' -d '{"method": "prod"}' http://localhost:3456/sdk/v1
Yes i have a physical sim from webbing, so when that is inserted, the esim page module disappears?
Webbing's eSIM card is not compatible with our eSIM program, so it is limited on the web page, and it is recommended to buy our physical SIM card on our esim store
ok - so the eSIM page module, only shows up when an eSIM is connected. correct?
i am using this sim.
https://store-us.gl-inet.com/collections/sim-card/products/webbing-card
so, when this is connected, the eSIM module page does not show.
The EID of sim card will be detected and if not those card provider's EIDs we supported,the esim page does not show.It doesn't matter if it's connected or not.
alright - thank you sir.
You're welcome and thanks for feedback!
