Im looking for way to activate my SD file storage.
I know for the mudi v2 it must be on the power adapter. I didnt but cant see yet where to manage the sd card.
Do i need another application for connection to the SD card ?
Thx
Thx
Guess you are on version 4.x?
In this version the file storage was removed due to performance issues.
You can manually install it: E750 - File Sharing Missing
Hey, yeah thats correct. Thx for the link and lets try if its just enough where for i wanna use it ^^ not wanna transfer big files.
Thanks a lot
