Hi, I set up my mudi v2 connected to my home wifi and connected my vpn service surfshark with the mudi. When I now connect the router with the laptop the wifi doesn’t work. When I try it with my private Mac laptop and not the work windows it works. Does that mean my work laptop is blocked for vpns even though it goes through the travel router. Is there a work around
Probably check if there is any network software like blocking traffic or VPN client on your work PC (Windows), but it over GL technical support range.
Is the whole work PC network abnormal, including webpage google.com?
What do you mean does not work?
Your laptop does not have Internet at all?
Your laptop does has normal Internet but not going via VPN?
Usually your work laptop has your company's vpn software so it is double VPN and the company vpn may not connect. Pls confirm if this is the case.
