Everytime my MUDI gets turned off/back on it loses the wifi channel for the 5ghz bandwidth. This prevents either 2.4ghz and the 5ghz band.
I am running latest firmware, any ideas why it keeps blanking out?
Thanks
Thanks
Are you using the latest push version 3.211? Or is it the latest 3.215 available on our download site?
Do you mean that the wifi is turned off in the settings or the signal is just disappeared while the settings is one?
@yuxin.zou The latest push version, 3.211.
@alzhao The wifi shows it is turned on, but the signal disappears on all devices for both bands until the channel is set again on the 5ghz channel. When I open settings the channel is blank.
Thanks
It looks like the channel is change to some DFS channel or wrong and wifi cannot be broadcasted.
Does this happen all the time?
Can you reset the firmware and configure again?
It pretty reliably clears out on boot, I can reset the firmware and configure again. I will give that a try.
