Mudi7 AmneziaWG Client issue
I exported an AmneziaWG config from my Brume 3 (firmware 4.8.4), all the Jc, Jmin etc. parameters are there in the config (which look like regular AmneziaWG 1.0 parameters). Then I imported this config in my Mudi7 (firmware 4.0). The import was successful but the obfuscation parameters were ignored during the import so the connection doesn't work.
I'm wondering if there's a configuration I need to change to make this work (it doesn't matter much for me if it's 1.0 or 2.0 protocol).
The current firmware version for the Mudi 7 does not yet support AmneziaWG. We do have plans to add support for it in the next firmware release.
For now, you may need to use standard WireGuard instead of AmneziaWG.
