Mudi7 GPS
I saw a post in a separate thread that the Mudi 7 GNSS antenna is not fully wired up. What is the exact state of the GNSS/GPS routing on the Mudi 7? Is the pin on the chip floating, grounded? Is it wired to one of the IPX connectors on the back? The GNSS pin is 271 if that helps.
Was curious about this myself. The X72 supports GNSS on paper, but I checked from the software side a while back — no /dev/ nodes for GNSS, no gpsd, modem's location service doesn't respond either. Nothing surfaces to userspace at the firmware level on my unit. Whether that's pin 271 physically unwired, or just the userspace bits disabled in the shipped image, can't tell from software alone.
We have confirmed that the GNSS antenna PIN is not connected to the IPX interface and is instead floating.
