Hi I'm using mudiv2 with firmware 4.7.2 beta. I also use the physical esim card bought from gl inet store.
Wondering what would happen to the esim profiles I have added if I do factory reset on the mudi? Will I lost them? or are they stored in the physical esim itself?
Hello Hansel The eSIM profiles are normally saved on the physical eSIM card itself rather than the internal memory of the device if you're using a physical eSIM card with your Mudi v2 running firmware 4.7.2 beta. This implies that your eSIM profiles shouldn't be erased when you perform a factory reset on the Mudi. For extra peace of mind, it's wise to double-check with the eSIM provider or backup any crucial configuration.
