Mudy 7 - BE5800 & Tmobile
Has anyone had any luck activating with Tmobilein the US? I called to do an esim activation and they said it was carrier locked to AT&T. I tried swapping in a sim from another hotspot and it would not connect.
I have a physical SIM that works fine on TMobile. I did notice that even though I don’t have an eSIM, the eSIM status does say “AT&T” which is interesting.
ive got a calyx (tmobile) sim and had no issues. i took it out of my spitz ax 3000. as te previous poster mentioned, out of the box i also saw ATT as well. im based in LA (usa).
You do not have to use AT&T eSIM and it can easily be removed. The Mudy 7 is compatible with other eSIM like Truphone, Ubigi, GigSky, Airalo, etc…
Thank you for the replies, I appreciate the help. I’ll contact T-Mobile again.
