Mullvad VPN add-on for Tailscale on GL-X2000
I have just bought my first GL.inet router, and was curious if there was support for Mullvad VPN add-on for Tailscale? Using the Mullvad servers as Exit Nodes?
Thanks!
Yes, the Mullvad VPN add-on for Tailscale is supported.
However, it only displays the IP address, not the location.
For how to configure the Tailscale Exit Node on router, please refer to:
