Multi-NAT
I've acquired a Flint 2 (GL-MT6000) as a replacement for my Draytek 2926.
I have a static IP block, and on the Draytek I could use NAT and port-forwarding rules to present interfaces on different external IPs.
I can't see a way to do that with the Flint.
Is there a solution to this?
Are there detailed manuals available for the routers?
I've had to stop using the Draytek due to the reboot doom loop, at least until they issue a new firmware.
GL GUI does not support getting multiple static IPs. Feel sorry.
You can configure multiple virtual WAN ports and multi static IPs in the Luci.
Refer this third-party blog
https://linuxconfig.org/configuring-virtual-network-interfaces-in-linux
