The exact procedure and whether a second MLO SSID is supported depend on the router’s Wi-Fi chipset and firmware branch. Please provide the router model and full firmware version shown under System → Overview; this will determine whether LuCI/UCI can create another MLO group and which options are required.
Until then, avoid applying the apparent LuCI configuration: incomplete MLO settings across the participating radios can disable those Wi-Fi interfaces, and later changes in the GL.iNet Admin Panel may overwrite manual wireless configuration.
On the Flint 4 with firmware v4.9.2, the GL.iNet Admin Panel documents one MLO Wi‑Fi network; the Guest Network is configured as separate per-band Wi‑Fi networks, not as a second MLO group. The current v4.9.x wireless documentation does not provide a supported LuCI/UCI procedure for creating an additional MLO SSID.
Although LuCI may expose related MediaTek options, that does not confirm that a second MLO group is supported by the vendor Wi‑Fi stack. Avoid applying those settings until GL.iNet staff confirm the required MLD configuration for v4.9.2, as an incomplete manual configuration could prevent the participating radios from starting or be overwritten by the Admin Panel.
Please try connecting to the router via SSH and running the following command to add a Guest MLO SSID:
# Keep the original files for rollback.
[ -f /root/wireless.before-guest-mlo ] ||
cp /etc/config/wireless /root/wireless.before-guest-mlo
[ -f /root/mlo.before-guest-mlo ] ||
cp /etc/config/mlo /root/mlo.before-guest-mlo
GUEST_MLO_SSID="$(uci -q get wireless.guest2g.ssid)-MLO"
GUEST_MLO_KEY="$(uci -q get wireless.guest2g.key)"
# Generate four different local/unicast MAC addresses and avoid existing ones.
while :; do
TAIL5="$(hexdump -n 5 -e '5/1 ":%02X"' /dev/urandom)"
MAC2="02${TAIL5}"
MAC5="06${TAIL5}"
MAC6="0A${TAIL5}"
MLDMAC="0E${TAIL5}"
uci show wireless | grep -qiE "$MAC2|$MAC5|$MAC6|$MLDMAC" || break
done
# Remove only an existing manual Guest MLO configuration.
for SECTION in wlanmldguest2g wlanmldguest5g wlanmldguest6g mld1; do
uci -q delete wireless.$SECTION
done
uci -q delete mlo.mld1
uci -q batch <<'EOF'
set wireless.wlanmldguest2g=wifi-iface
set wireless.wlanmldguest2g.device='MT7990_1_1'
set wireless.wlanmldguest2g.network='guest'
set wireless.wlanmldguest2g.mode='ap'
set wireless.wlanmldguest2g.encryption='sae'
set wireless.wlanmldguest2g.wds='1'
set wireless.wlanmldguest2g.isolate='1'
set wireless.wlanmldguest2g.hidden='0'
set wireless.wlanmldguest2g.ifname='ra4'
set wireless.wlanmldguest2g.vifidx='5'
set wireless.wlanmldguest2g.ieee80211k='1'
set wireless.wlanmldguest2g.bss_transition='1'
set wireless.wlanmldguest2g.mld='mld1'
set wireless.wlanmldguest2g.guest='1'
set wireless.wlanmldguest2g.init='1'
set wireless.wlanmldguest2g.disabled='0'
set wireless.wlanmldguest5g=wifi-iface
set wireless.wlanmldguest5g.device='MT7990_1_2'
set wireless.wlanmldguest5g.network='guest'
set wireless.wlanmldguest5g.mode='ap'
set wireless.wlanmldguest5g.encryption='sae'
set wireless.wlanmldguest5g.wds='1'
set wireless.wlanmldguest5g.isolate='1'
set wireless.wlanmldguest5g.hidden='0'
set wireless.wlanmldguest5g.ifname='rai4'
set wireless.wlanmldguest5g.vifidx='5'
set wireless.wlanmldguest5g.ieee80211k='1'
set wireless.wlanmldguest5g.bss_transition='1'
set wireless.wlanmldguest5g.mld='mld1'
set wireless.wlanmldguest5g.guest='1'
set wireless.wlanmldguest5g.init='1'
set wireless.wlanmldguest5g.disabled='0'
set wireless.wlanmldguest6g=wifi-iface
set wireless.wlanmldguest6g.device='MT7990_1_3'
set wireless.wlanmldguest6g.network='guest'
set wireless.wlanmldguest6g.mode='ap'
set wireless.wlanmldguest6g.encryption='sae'
set wireless.wlanmldguest6g.sae_pwe='1'
set wireless.wlanmldguest6g.wds='1'
set wireless.wlanmldguest6g.isolate='1'
set wireless.wlanmldguest6g.hidden='0'
set wireless.wlanmldguest6g.ifname='rax4'
set wireless.wlanmldguest6g.vifidx='4'
set wireless.wlanmldguest6g.ieee80211k='1'
set wireless.wlanmldguest6g.bss_transition='1'
set wireless.wlanmldguest6g.mld='mld1'
set wireless.wlanmldguest6g.guest='1'
set wireless.wlanmldguest6g.init='1'
set wireless.wlanmldguest6g.disabled='0'
set wireless.mld1=wifi-mld
set wireless.mld1.eht_t2lmnegosupport='1'
set wireless.mld1.mode='ap'
set wireless.mld1.encryption='sae'
set wireless.mld1.hidden='0'
set wireless.mld1.mldgroup='2'
set wireless.mld1.guest='1'
set wireless.mld1.isolate='1'
set wireless.mld1.disabled='0'
set wireless.mld1.init='1'
set wireless.mld1.iface='ra4 rai4 rax4'
set mlo.mld1=wifi-mld
set mlo.mld1.disabled='0'
add_list mlo.mld1.bands='2g'
add_list mlo.mld1.bands='5g'
add_list mlo.mld1.bands='6g'
EOF
# Apply the separate SSID, existing Guest password, and generated MACs.
for SECTION in wlanmldguest2g wlanmldguest5g wlanmldguest6g; do
uci set wireless.$SECTION.ssid="$GUEST_MLO_SSID"
uci set wireless.$SECTION.key="$GUEST_MLO_KEY"
done
uci set wireless.wlanmldguest2g.macaddr="$MAC2"
uci set wireless.wlanmldguest5g.macaddr="$MAC5"
uci set wireless.wlanmldguest6g.macaddr="$MAC6"
uci set wireless.mld1.ssid="$GUEST_MLO_SSID"
uci set wireless.mld1.key="$GUEST_MLO_KEY"
uci set wireless.mld1.mld_macaddr="$MLDMAC"
uci set mlo.mld1.mld_macaddr="$MLDMAC"
uci commit wireless
uci commit mlo
wifi reload
