New to Openwrt (running on pcwrt now) and very little experience tinkering with it so bear with me if this is a newbie Q. Have been searching the forums but have not been able to find a direct answer.
I’m interested in the Velica but was hoping someone could chime in on setting up multiple SSIDs/Vlans as well as using them in a mesh network. My understanding is aside from 1 Guest network you have to use LuCi or command to setup multiple SSIDs/VLANS. Assuming this is not that hard to do but a few Q’s on it:
-Will mesh network work with all the multiple SSIDs?
-Do network isolation settings work?
-Are you able to use GLs UI and features with the different SSIDs? For example, have VPN or Adblock setup for only one of the SSIDs or assign a specific VLAN to the ethernet port.
-Does VLAN port tagging work with this scenerio to setup APs with multiple SSIDs?
I know most if not all of these are possible on OpenWRT but if I can even figure out how to setup them up through luci will they break GLs UI settings and features?
Thanks for taking the time.
