I have Slate Plus.
I want to connect two different openvpn servers as a client and I want to use two diffrent connection wifi or ethernet ports?
Is it possible with gli? If not, how can I do it by using openwrt?
I have Slate Plus.
Using “Customize Routing Rules” mode, you can enable wireguard and OpenVPN client at the same time. But they’re going through the same gateway(ethernet/wifi).
So not possible yet.
Hi, how I can achieve that? (ovpn+wg tunnel?)
what i have to add in custom rules?
Eample:
The default route is by wireguard, and certain Intranet(192.168.173.0/24) is by OpenVPN client.
Dual VPN client:
Openvpn route rule:
Wireguard route rule:
Can you please detailed your solutions.
Because I’m checking to do the same with my GL-AX1800 but doesn’t work with both activated in the same time like per image attached
Thank you
Turning to “Customize Routing Rules” mode is necessary.
i used this with “Customize Routing Rules” and it worked perfectly on my AXT1800.
Openvpn Client together with an Wireguard VPN.
Had 3 routes for the Wireguard connection:
192.168.178.0/24 0 Metric
0.0.0.0/1 1000 Metric
128.0.0/1 1000 Metric
1 Route for OpenVPN:
10.0.0.0/24 0 Metric
It worked without a Problem, but after updating to 4.5 the webinterface stops responding and there is no connection possible.
The problem relays on the routes 0.0.0.0/1 and 128.0.0.0/1.
If I use the global proxy the 0.0.0.0/0 route is in Table “8000”,
In “Customize Routing Rules” Mode the routes are in the main table.
Maybe there is the problem?
My target address is formatted with words as its a vpn provider so its ''east-london**************.com
and the UI Is rejecting it but it is the conected server?
Also I am a Flint 2 owner
Not sure what kind of GUI we see here, but the target can only be an IP address.
how to choose devices on each vpn?
one i have goes to offsite backup location
and i want one open vpn for streaming separate
so
open vpn
device 1 - VPN
device 2 - vpn
device 3 - no vpn
wireguard - offsite backup server on always
this is what I wish to happen ![]()
