Multiple VPN Clients - one for each connected device
How can I set up multiple VPN client connections, so that I can assign one VPN for each connected LAN device?
Can I do this with OpenWRT or LUCI GUI?
The could be possible but too complicated.
In our firmware 4.x we are allowing openvpn and wireguard connection at the same time and set up complete route.
Look into tailscale its awesome
Thank you, how can I do this over the Luci interface? I really need this to work somehow
You need to install luci, luci-app-openvpn, luci-app-wireguard then you will have Luci interface.
I have done that and setup multiple OpenVPNs, created unmanaged interfaces for each one and added them all to the red firewall zone: wan.
What exactly do I have to do now?
I also installed mwan3 and VPN policy based routing.
What I want to achieve:
Each LAN device should have it’s own VPN assigned.
If a device is not connected to a VPN it should not have an internet connection.
hello , iam a newbie, so if i can have screenshot , i will apprecied
It’s quite the same as ZeroTier, no?
i find that zerotier is better then tailscale now
Do you have any insights about zerotier and tailscale?
Zerotier is awesome i can do wake on lan won’t work on tail. Its just so much easier to setup and its more dependable i have it on all of my devices i even use the rdp protocol works great and i can even close all ports on my nas and still have access and even bypass CGNAT. On blocked or closed ports.
tailscale website is much easier to use, especially when it comes to create traffic rules.
but both tailscale and zerotier are great, stable, free and open source.
