Hello, I have a question before buying one of the vpn routers. I don’t know how to call it. So I try to describe the use case.
Can I set them up like this (example)?
MacBook uses German VPN
Windows Laptop uses USA VPN
iPhone uses Spain VPN
All connections would be at the same time. If it is possible would it work on all the routers? I’m mostly looking for the travel ones.
Thank you for the help!
