when the update will come for the brume??, i keep having disconnection problem almost everyday since December, i tried all the beta firmware one by one, but still have the same issue. my brume is connected to the awus036ac and im using it as a repeater , and after 1 or 2 days of use , it drop the connection, i have to restard and connect again by typing the ssid password. so i downgrade to 3.105 because its the most stable right now, but its really annoying, almost a year that im fighting with this rooter, i bought it because it was supposed to make my life better , and an official update was supposed to be release end of may, we are in august and still nothing ![]()
We will release the firmware today or tomorrow. But as you said the beta firmware has problems as well. So it may not solve your issue.
Did you contact support via email and send the log?
no, how can i get the log ?
Ssh to the router and use command
logread
Refund perhaps or send back the router empty so you can fiilit whit good stuff count me in hehe
sorry alzhao, but how to do a SSH to the router ? ![]()
We will release the firmware today or tomorrow when is that ?
This Wi-Fi dongle is especially designed for the GL-MV1000 i have better connection whit the built in wifi than this
Can you delete mine account in here glinet forum cant find it in preference
Done. You are anonymous now.
thanks you alzhao ![]()
wow…i remember putty…my age has been leaked
Perhaps the disconnect is happening because Brume is trying to connect to the origin SSID WiFi, for WAN; yet the Ethernet cable is connected from another router or origin into the WAN port?
root@30uter_0z:~# logread
Fri Dec 23 23:23:24 2022 kern.info kernel: [ 431.278402] br-lan: port 4(wlan0) entered blocking state
Fri Dec 23 23:23:24 2022 kern.info kernel: [ 431.284021] br-lan: port 4(wlan0) entered disabled state
Fri Dec 23 23:23:24 2022 kern.info kernel: [ 431.290032] device wlan0 entered promiscuous mode
Fri Dec 23 23:23:24 2022 kern.info kernel: [ 431.295050] br-lan: port 4(wlan0) entered blocking state
Fri Dec 23 23:23:24 2022 kern.info kernel: [ 431.300503] br-lan: port 4(wlan0) entered forwarding state
Fri Dec 23 23:23:24 2022 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Fri Dec 23 23:23:25 2022 kern.info kernel: [ 431.803096] br-lan: port 4(wlan0) entered disabled state
Fri Dec 23 23:23:25 2022 daemon.err hostapd: Using interface wlan0 with hwaddr 00:c0:ca:a6:82:78 and ssid "XXXXX"
Fri Dec 23 23:23:25 2022 kern.info kernel: [ 432.172519] br-lan: port 4(wlan0) entered blocking state
Fri Dec 23 23:23:25 2022 kern.info kernel: [ 432.178099] br-lan: port 4(wlan0) entered forwarding state
Fri Dec 23 23:23:25 2022 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Fri Dec 23 23:23:25 2022 daemon.notice hostapd: wlan0: AP-ENABLED
Fri Dec 23 23:23:25 2022 daemon.notice netifd: Network device 'wlan0' link is up
Fri Dec 23 23:23:26 2022 daemon.info hostapd: wlan0: STA XX:XX:XX:XX:XX:XX IEEE 802.11: associated
Fri Dec 23 23:23:26 2022 daemon.notice hostapd: wlan0: AP-STA-CONNECTED e4:b3:18:2d:0d:fc
Fri Dec 23 23:23:26 2022 daemon.info hostapd: wlan0: STA XX:XX:XX:XX:XX:XX RADIUS: starting accounting session CE51791EFF0DCDB8
Fri Dec 23 23:23:26 2022 daemon.info hostapd: wlan0: STA XX:XX:XX:XX:XX:XX WPA: pairwise key handshake completed (RSN)
Fri Dec 23 23:23:28 2022 daemon.info dnsmasq-dhcp[3660]: DHCPDISCOVER(br-lan) 172.21.15.123 e4:b3:18:2d:0d:fc
Fri Dec 23 23:23:28 2022 daemon.info dnsmasq-dhcp[3660]: DHCPOFFER(br-lan) 172.21.15.123 e4:b3:18:2d:0d:fc
Fri Dec 23 23:23:28 2022 daemon.info dnsmasq-dhcp[3660]: DHCPREQUEST(br-lan) 172.21.15.123 e4:b3:18:2d:0d:fc
Fri Dec 23 23:23:28 2022 daemon.info dnsmasq-dhcp[3660]: DHCPACK(br-lan) 172.21.15.123 e4:b3:18:2d:0d:fc mx1
Fri Dec 23 23:24:34 2022 user.info : [ 2910] gl-wifi-core>> bIsStaEnabled=1
Fri Dec 23 23:24:35 2022 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Fri Dec 23 23:24:35 2022 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
Fri Dec 23 23:24:35 2022 daemon.notice hostapd: wlan0: AP-DISABLED
Fri Dec 23 23:24:35 2022 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Fri Dec 23 23:24:35 2022 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Fri Dec 23 23:24:35 2022 kern.info kernel: [ 501.809710] device wlan0 left promiscuous mode
Fri Dec 23 23:24:35 2022 kern.info kernel: [ 501.814804] br-lan: port 4(wlan0) entered disabled state
Fri Dec 23 23:24:35 2022 daemon.notice netifd: bridge 'br-lan' link is down
Fri Dec 23 23:24:35 2022 daemon.notice netifd: Interface 'lan' has link connectivity loss
Fri Dec 23 23:24:35 2022 daemon.notice netifd: Network device 'wlan0' link is down
Fri Dec 23 23:24:37 2022 daemon.notice netifd: radio0 (18700): sh: out of range
Fri Dec 23 23:24:37 2022 daemon.notice wpa_supplicant[18769]: Successfully initialized wpa_supplicant
Fri Dec 23 23:24:37 2022 daemon.notice netifd: radio0 (18700): command failed: No such device (-19)
Fri Dec 23 23:24:37 2022 user.notice mac80211: Failed command: iw phy phy0 interface add wlan0 type __ap
Fri Dec 23 23:24:37 2022 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Fri Dec 23 23:24:37 2022 daemon.notice netifd: radio0 (18700): sh: /usr/bin/ovs-vsctl: not found
Fri Dec 23 23:24:37 2022 kern.info kernel: [ 504.123930] br-lan: port 4(wlan0) entered blocking state
Fri Dec 23 23:24:37 2022 kern.info kernel: [ 504.129270] br-lan: port 4(wlan0) entered disabled state
Fri Dec 23 23:24:37 2022 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Fri Dec 23 23:24:37 2022 kern.info kernel: [ 504.135195] device wlan0 entered promiscuous mode
Fri Dec 23 23:24:37 2022 daemon.notice netifd: Interface 'wwan' is enabled
Fri Dec 23 23:24:38 2022 daemon.err hostapd: Using interface wlan0 with hwaddr 00:c0:ca:a6:82:78 and ssid "XXXXX"
Fri Dec 23 23:24:38 2022 daemon.notice wpa_supplicant[18782]: wlan1: Trying to associate with f4:92:bf:af:f4:ea (SSID='YYYYY' freq=5240 MHz)
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 504.859100] ------------[ cut here ]------------
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 504.863910] WARNING: CPU: 0 PID: 4560 at cfg80211_ch_switch_notify+0x4c/0x23c8 [cfg80211]
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 504.872390] Modules linked in: 8811au 8812au 8821cu pppoe ppp_async option usb_wwan sierra pppox ppp_mppe ppp_generic nf_nat_pptp nf_conntrack_pptp iptable_nat ipt_REJECT ipt_MASQUERADE ebtable_nat ebtable_filter ebtable_broute xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_helper xt_hashlimit xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_IPMARK xt_HL xt_FLOWOFFLOAD xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial ts_fsm ts_bm slhc sierra_net rndis_host nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_conntrack_ipv4 nf_nat_ipv4 nf_nat_h323 nf_nat_ftp nf_nat_amanda nf_log_ipv4 nf_flow_table_hw
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 504.945897] nf_flow_table nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast ts_kmp nf_conntrack_amanda macvlan iptable_raw iptable_mangle iptable_filter ipt_ECN ipheth ip_tables huawei_cdc_ncm ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt compat_xtables cdc_ncm cdc_ether cdc_acm xt_u32 8192eu cfg80211 compat sch_teql sch_sfq sch_red sch_prio sch_pie sch_multiq sch_gred sch_fq sch_dsmark sch_codel sch_cbq em_text em_nbyte em_meta em_cmp act_simple act_police act_pedit act_ipt act_gact act_csum libcrc32c act_connmark sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_tcindex
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 505.019225] cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred usb_f_ecm g_ether usb_f_rndis u_ether libcomposite xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6t_NPT ip6t_MASQUERADE nf_nat_masquerade_ipv6 nf_nat nf_conntrack nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 ip6_udp_tunnel udp_tunnel tun vfat fat ntfs configfs nls_utf8 nls_iso8859_1 nls_cp437 ecb fuse uas uhci_hcd ohci_platform ohci_hcd gpio_button_hotplug
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 505.093990] exfat
Fri Dec 23 23:24:38 2022 kern.warn kernel: [ 505.095893] CPU: 0 PID: 4560 Comm: RTW_CMD_THREAD Tainted: G W 4.14.241 #0
