Will the VPN speeds of the brume improved with updates or its a done deal on that regards?
What a mean it’s, my wifi router has less powerful hardware and I get faster OVPN speeds with it, only reason I put the brume in front of it was to try wireguard witch it’s not supported by my router firmware.
Thanks for the info
I just got my brume its a little disappointed.
But anyway, let’s see how the Flint comes price wise, and I heard it has an old SDK and an old kernel, I’m going to wait for a few updates and see what you guys said
You should still be able to get the advertised 97 Mbps on OpenVPN using the BRUME. You may want to switch to AES-128-CBC to get the best possible throughput, using 256-CBC or 128-GCM/256-GCM are more taxing on the processor.
It is a variable on the .ovpn config, if you’re connecting to a commercial VPN provider.
It will look like:
cipher AES-256-GCM
Just change this line to:
cipher AES-128-CBC
This requires that your commericial VPN provider supports the cipher, it probably does, but it’s not guaranteed.
If you’re setting up your BRUME as a server, there is likewise a configuration setting to change the preferred cipher. But if you’re using it as a server you should really move to the more peformant WireGuard, it knocks the socks off of OpenVPN. I would also consider moving to a commercial VPN that supports WireGuard as well, like Mullvad, AzireVPN, Windscribe and many others.
Thanks
I’m using the brume as a client in front of my network, my provider it’s protonvpn, I did try wireguard for a few days with Mullvad and indeed it’s really fast, but unfortunately Proton it’s not supporting wireguard configuration files at the moment so for now I’m stuck with OVPN.
