using MV1000 as Wireguard Client and connect to B1300 Wireguard Server
an error show on INTERNET with WG!
THEN
connect to MV1000 SSID and show NO INTERNET
AND
can not browse the MV1000 login portal
Any suggestion?
THEN
AND
Any suggestion?
Yes : what is in the logs ? what are the IP adresses ? what can you ping ? Does DNS work ?
Did you change IP address of one router from 192.168.8.1 to others?
After change the WireGuard Client (MV1000) to different lan ip address,
Can —
Route table on MV1000
cannot—
note that the Wireguard Server (B1300) under dynamic public ip
so the endpoint ips configuration have to check same peer on Wireguard client MV1000
I noticed your IP is in China. If your server is outside of China you are likely to have a problem because of the firewall.
