chchang
February 8, 2021, 10:43am
I buy couple MV1000 to test goodcloud S2S VPN a few days ago.
and today I want to test file transfer , found that the VPN connection speed is really slow.
here is my architecture diagram
](https://i.imgur.com/JKLTfzV.png )
ALL ethernet port was 1000 mbps/full duplex
so , I run iperf3 in the laptop behind 60 subnet , and use another laptop in 11 subnet ( wan) as client
and the result is
chchang@hqdc039:~/git$ iperf3 -c 192.168.11.60 -t 10
Connecting to host 192.168.11.60, port 5201
[ 5] local 192.168.11.39 port 45368 connected to 192.168.11.60 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 11.4 MBytes 95.7 Mbits/sec 12 79.2 KBytes
[ 5] 1.00-2.00 sec 11.2 MBytes 94.4 Mbits/sec 6 65.0 KBytes
[ 5] 2.00-3.00 sec 10.9 MBytes 91.2 Mbits/sec 8 65.0 KBytes
[ 5] 3.00-4.00 sec 11.1 MBytes 92.8 Mbits/sec 9 63.6 KBytes
[ 5] 4.00-5.00 sec 11.1 MBytes 93.3 Mbits/sec 5 69.3 KBytes
[ 5] 5.00-6.00 sec 11.2 MBytes 93.8 Mbits/sec 5 73.5 KBytes
[ 5] 6.00-7.00 sec 10.9 MBytes 91.7 Mbits/sec 6 79.2 KBytes
[ 5] 7.00-8.00 sec 10.9 MBytes 91.7 Mbits/sec 6 79.2 KBytes
[ 5] 8.00-9.00 sec 11.2 MBytes 93.8 Mbits/sec 6 82.0 KBytes
[ 5] 9.00-10.00 sec 10.9 MBytes 91.2 Mbits/sec 7 63.6 KBytes
[ 5] 0.00-10.00 sec 111 MBytes 93.0 Mbits/sec 70 sender
[ 5] 0.00-10.01 sec 111 MBytes 92.7 Mbits/sec receiver
iperf Done.
what !? only 90 Mb !? why ? I don’t undestand !
I can accept that the VPN is less efficient, but less than 1/10 is pretty bad
is there anything I should but I didn’t noticed ??
DienoX
February 8, 2021, 11:51am
2
Try to forward the iperf3 port and then measure the bandwidth without a VPN. It seems to me that the problem lies with the internet provider, and more specifically with the routing between operators.
chchang
February 9, 2021, 12:15am
3
it should be nothing related to internet provider , the traffic should be all in the LAN.
and I didn’t know the routing info , all VPN was connected via goodcloud service .
I didn’t add/modify any routing.
alzhao
February 10, 2021, 3:47am
4
From your figner I don’t see S2S set up.
Is the 50.1 and 60.1 are two boxes at different locations, or it is in the same LAN of 11.1/24 network?
How does the vpn set up?
From your diagram everything is in one subnet and I don’t see how it relates to S2S.
chchang
February 10, 2021, 8:18am
5
50.1 and 60.1 are both in 11 network
that two machines use 11 network as their WAN
It’s just a testing environment.
VPN configure by goodcloud S2S
alzhao
February 10, 2021, 8:23am
6
OK I see.
But 90+mbps is still bad performance?
chchang
February 10, 2021, 2:52pm
7
According to GL-MV1000 / Brume - GL.iNet
WireGuard VPN maximum speed 280 mbps
I was expecting something around 200
alzhao
February 11, 2021, 2:01am
8
280 is when it is working as wireguard client. For S2S I don’t know.
Eli
February 13, 2021, 5:43am
9
What speed do you get from mv1000 with OpenVPN and Ethernet/WiFi on power supply?
chchang
February 13, 2021, 8:53am
10
I didn’t try openvpn. is that necessary to compare openvpn and WireGuard?
Eli
February 13, 2021, 10:10am
11
No, it’s necessary to compare speeds achieved in practice to what is advertised for each case.
Wireguard support is limited at this point.
I can repot my speeds later today.
Eli
February 13, 2021, 8:57pm
12
My OpenVPN speeds are same as the ones reported here: around 25 mbs upload and 45mbs download, with Ethernet and power supply:
chchang
February 17, 2021, 5:42am
13
Well, they claim the openvpn speed is around 97 mbps, don’t you think a half lost is not acceptable?
