Hi Everyone,
I’m building my own imagebuilder and I’m trying to figure out a list of all of the firmware and Kernel Modules I need to include to get the hardware working.
So far I’ve included the package below.
Kernel modules > Network Devices
kmod-switch-mvsw61xx… Marvell 88E61xx switch support
This allowed me to get the wired interfaces working. Now I’m trying to find out what I need for the wireless interface. After doing some sleuthing around on the FCC site for the chipset used I found the RTL8192CU/EU listed as the chipset.
I loaded up the OEM firmware too and did a
dmesg | grep -i driver
Which led me to a list of additional drivers to include.
The list of the included drivers and firmware.
reza@reza-ThinkPad-X260:~/mv1000/openwrt$ grep rtl .config | grep -v “#”
CONFIG_PACKAGE_rtl8188eu-firmware=y
CONFIG_PACKAGE_rtl8192cu-firmware=y
CONFIG_PACKAGE_rtl8192eu-firmware=y
CONFIG_PACKAGE_rtl8821ae-firmware=y
CONFIG_PACKAGE_kmod-usb-net-rtl8150=y
CONFIG_PACKAGE_kmod-usb-net-rtl8152=y
CONFIG_PACKAGE_kmod-rtl8192c-common=y
CONFIG_PACKAGE_kmod-rtl8192cu=y
CONFIG_PACKAGE_kmod-rtl8812au-ct=y
CONFIG_PACKAGE_kmod-rtl8821ae=y
CONFIG_PACKAGE_kmod-rtl8xxxu=y
CONFIG_PACKAGE_kmod-rtlwifi=y
CONFIG_PACKAGE_kmod-rtlwifi-btcoexist=y
CONFIG_PACKAGE_kmod-rtlwifi-pci=y
CONFIG_PACKAGE_kmod-rtlwifi-usb=y
I compiled the imagebuilder in my environment and am able to load up the firmware onto the GL-MV1000W, but I’m still unable to detect the wireless interfaces.
I tried searching around on the web for specification of the 1000W (wireless) specifically, but only found references to the MV1000 (non-wireless).
I will post my full config file in the 2nd message.
Thanks for any assistance.
Here is the .config file I’m using to build my environment. I’m hoping someone knows of a package I missed or know the right firmware and modules to use for the wireless on these devices.
Ensure I’ve got the latest commits on and on the right branch for MV1000W, which is 19.07.07
reza@reza-ThinkPad-X260:~/mv1000/openwrt$ git pull ; git branch ; date
Already up to date.
openwrt-19.07.7
Fri May 21 11:18:39 PDT 2021
I’ve removed the commented out lines.
reza@reza-ThinkPad-X260:~/mv1000/openwrt$ grep -o ‘*’ .config
CONFIG_MODULES=y
CONFIG_HAVE_DOT_CONFIG=y
CONFIG_TARGET_mvebu=y
CONFIG_TARGET_mvebu_cortexa53=y
CONFIG_TARGET_mvebu_cortexa53_DEVICE_gl-mv1000-emmc=y
CONFIG_HAS_SUBTARGETS=y
CONFIG_HAS_DEVICES=y
CONFIG_TARGET_BOARD=“mvebu”
CONFIG_TARGET_SUBTARGET=“cortexa53”
CONFIG_TARGET_PROFILE=“DEVICE_gl-mv1000-emmc”
CONFIG_TARGET_ARCH_PACKAGES=“aarch64_cortex-a53”
CONFIG_DEFAULT_TARGET_OPTIMIZATION=“-Os -pipe -mcpu=cortex-a53”
CONFIG_CPU_TYPE=“cortex-a53”
CONFIG_LINUX_4_14=y
CONFIG_DEFAULT_base-files=y
CONFIG_DEFAULT_busybox=y
CONFIG_DEFAULT_dnsmasq=y
CONFIG_DEFAULT_dropbear=y
CONFIG_DEFAULT_e2fsprogs=y
CONFIG_DEFAULT_ethtool=y
CONFIG_DEFAULT_firewall=y
CONFIG_DEFAULT_fstools=y
CONFIG_DEFAULT_ip6tables=y
CONFIG_DEFAULT_iptables=y
CONFIG_DEFAULT_kmod-gpio-button-hotplug=y
CONFIG_DEFAULT_kmod-ipt-offload=y
CONFIG_DEFAULT_libc=y
CONFIG_DEFAULT_libgcc=y
CONFIG_DEFAULT_logd=y
CONFIG_DEFAULT_mkf2fs=y
CONFIG_DEFAULT_mtd=y
CONFIG_DEFAULT_netifd=y
CONFIG_DEFAULT_odhcp6c=y
CONFIG_DEFAULT_odhcpd-ipv6only=y
CONFIG_DEFAULT_opkg=y
CONFIG_DEFAULT_partx-utils=y
CONFIG_DEFAULT_ppp=y
CONFIG_DEFAULT_ppp-mod-pppoe=y
CONFIG_DEFAULT_uboot-envtools=y
CONFIG_DEFAULT_uci=y
CONFIG_DEFAULT_uclient-fetch=y
CONFIG_DEFAULT_urandom-seed=y
CONFIG_DEFAULT_urngd=y
CONFIG_HAS_FPU=y
CONFIG_AUDIO_SUPPORT=y
CONFIG_GPIO_SUPPORT=y
CONFIG_PCI_SUPPORT=y
CONFIG_PCIE_SUPPORT=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_GADGET_SUPPORT=y
CONFIG_RTC_SUPPORT=y
CONFIG_USES_DEVICETREE=y
CONFIG_USES_INITRAMFS=y
CONFIG_USES_SQUASHFS=y
CONFIG_USES_EXT4=y
CONFIG_NAND_SUPPORT=y
CONFIG_ARCH_64BIT=y
CONFIG_USES_ROOTFS_PART=y
CONFIG_USES_BOOT_PART=y
CONFIG_aarch64=y
CONFIG_arm_v7=y
CONFIG_ARCH=“aarch64”
CONFIG_TARGET_ROOTFS_INITRAMFS=y
CONFIG_TARGET_INITRAMFS_COMPRESSION_NONE=y
CONFIG_EXTERNAL_CPIO=“”
CONFIG_TARGET_ROOTFS_EXT4FS=y
CONFIG_TARGET_EXT4_RESERVED_PCT=0
CONFIG_TARGET_EXT4_BLOCKSIZE_4K=y
CONFIG_TARGET_EXT4_BLOCKSIZE=4096
CONFIG_TARGET_ROOTFS_SQUASHFS=y
CONFIG_TARGET_SQUASHFS_BLOCK_SIZE=256
CONFIG_TARGET_UBIFS_FREE_SPACE_FIXUP=y
CONFIG_TARGET_UBIFS_JOURNAL_SIZE=“”
CONFIG_TARGET_IMAGES_GZIP=y
CONFIG_TARGET_KERNEL_PARTSIZE=16
CONFIG_TARGET_ROOTFS_PARTSIZE=512
CONFIG_SIGNED_PACKAGES=y
CONFIG_SIGNATURE_CHECK=y
CONFIG_SHADOW_PASSWORDS=y
CONFIG_KERNEL_BUILD_USER=“”
CONFIG_KERNEL_BUILD_DOMAIN=“”
CONFIG_KERNEL_PRINTK=y
CONFIG_KERNEL_CRASHLOG=y
CONFIG_KERNEL_SWAP=y
CONFIG_KERNEL_DEBUG_FS=y
CONFIG_KERNEL_KALLSYMS=y
CONFIG_KERNEL_DEBUG_KERNEL=y
CONFIG_KERNEL_DEBUG_INFO=y
CONFIG_KERNEL_MAGIC_SYSRQ=y
CONFIG_KERNEL_COREDUMP=y
CONFIG_KERNEL_ELF_CORE=y
CONFIG_KERNEL_PRINTK_TIME=y
CONFIG_KERNEL_IP_MROUTE=y
CONFIG_KERNEL_IPV6=y
CONFIG_KERNEL_IPV6_MULTIPLE_TABLES=y
CONFIG_KERNEL_IPV6_SUBTREES=y
CONFIG_KERNEL_IPV6_MROUTE=y
CONFIG_KERNEL_SQUASHFS_FRAGMENT_CACHE_SIZE=3
CONFIG_KERNEL_CC_OPTIMIZE_FOR_PERFORMANCE=y
CONFIG_IPV6=y
CONFIG_USE_SSTRIP=y
CONFIG_USE_UCLIBCXX=y
CONFIG_PKG_CHECK_FORMAT_SECURITY=y
CONFIG_PKG_CC_STACKPROTECTOR_REGULAR=y
CONFIG_KERNEL_CC_STACKPROTECTOR_REGULAR=y
CONFIG_KERNEL_STACKPROTECTOR=y
CONFIG_PKG_FORTIFY_SOURCE_1=y
CONFIG_PKG_RELRO_FULL=y
CONFIG_BINARY_FOLDER=“”
CONFIG_DOWNLOAD_FOLDER=“”
CONFIG_LOCALMIRROR=“”
CONFIG_AUTOREBUILD=y
CONFIG_BUILD_SUFFIX=“”
CONFIG_TARGET_ROOTFS_DIR=“”
CONFIG_EXTERNAL_KERNEL_TREE=“”
CONFIG_KERNEL_GIT_CLONE_URI=“”
CONFIG_EXTRA_OPTIMIZATION=“-fno-caller-saves -fno-plt”
CONFIG_GLINET_OPENVPN=y
CONFIG_TARGET_OPTIMIZATION=“-Os -pipe -mcpu=cortex-a53”
CONFIG_EXTRA_BINUTILS_CONFIG_OPTIONS=“”
CONFIG_EXTRA_GCC_CONFIG_OPTIONS=“”
CONFIG_GDB=y
CONFIG_USE_MUSL=y
CONFIG_SSP_SUPPORT=y
CONFIG_BINUTILS_VERSION_2_31_1=y
CONFIG_BINUTILS_VERSION=“2.31.1”
CONFIG_GCC_VERSION=“7.5.0”
CONFIG_LIBC=“musl”
CONFIG_TARGET_SUFFIX=“musl”
CONFIG_IB=y
CONFIG_IB_STANDALONE=y
CONFIG_MAKE_TOOLCHAIN=y
CONFIG_TARGET_PREINIT_SUPPRESS_STDERR=y
CONFIG_TARGET_PREINIT_TIMEOUT=2
CONFIG_TARGET_PREINIT_IFNAME=“”
CONFIG_TARGET_PREINIT_IP=“192.168.1.1”
CONFIG_TARGET_PREINIT_NETMASK=“255.255.255.0”
CONFIG_TARGET_PREINIT_BROADCAST=“192.168.1.255”
CONFIG_TARGET_INIT_PATH=“/usr/sbin:/usr/bin:/sbin:/bin”
CONFIG_TARGET_INIT_ENV=“”
CONFIG_TARGET_INIT_CMD=“/sbin/init”
CONFIG_TARGET_INIT_SUPPRESS_STDERR=y
CONFIG_PER_FEED_REPO=y
CONFIG_FEED_packages=y
CONFIG_PACKAGE_base-files=y
CONFIG_PACKAGE_bridge=y
CONFIG_PACKAGE_busybox=y
CONFIG_BUSYBOX_CUSTOM=y
CONFIG_BUSYBOX_DEFAULT_HAVE_DOT_CONFIG=y
CONFIG_BUSYBOX_DEFAULT_INCLUDE_SUSv2=y
CONFIG_BUSYBOX_DEFAULT_LONG_OPTS=y
CONFIG_BUSYBOX_DEFAULT_SHOW_USAGE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VERBOSE_USAGE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_COMPRESS_USAGE=y
CONFIG_BUSYBOX_DEFAULT_LFS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_DEVPTS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_PIDFILE=y
CONFIG_BUSYBOX_DEFAULT_PID_FILE_PATH=“/var/run”
CONFIG_BUSYBOX_DEFAULT_FEATURE_SUID=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_PREFER_APPLETS=y
CONFIG_BUSYBOX_DEFAULT_BUSYBOX_EXEC_PATH=“/proc/self/exe”
CONFIG_BUSYBOX_DEFAULT_FEATURE_SYSLOG=y
CONFIG_BUSYBOX_DEFAULT_PLATFORM_LINUX=y
CONFIG_BUSYBOX_DEFAULT_CROSS_COMPILER_PREFIX=“”
CONFIG_BUSYBOX_DEFAULT_SYSROOT=“”
CONFIG_BUSYBOX_DEFAULT_EXTRA_CFLAGS=“”
CONFIG_BUSYBOX_DEFAULT_EXTRA_LDFLAGS=“”
CONFIG_BUSYBOX_DEFAULT_EXTRA_LDLIBS=“”
CONFIG_BUSYBOX_DEFAULT_INSTALL_APPLET_SYMLINKS=y
CONFIG_BUSYBOX_DEFAULT_PREFIX=“./_install”
CONFIG_BUSYBOX_DEFAULT_NO_DEBUG_LIB=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_BUFFERS_GO_ON_STACK=y
CONFIG_BUSYBOX_DEFAULT_PASSWORD_MINLEN=6
CONFIG_BUSYBOX_DEFAULT_MD5_SMALL=1
CONFIG_BUSYBOX_DEFAULT_SHA3_SMALL=1
CONFIG_BUSYBOX_DEFAULT_FEATURE_FAST_TOP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_EDITING=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_EDITING_MAX_LEN=512
CONFIG_BUSYBOX_DEFAULT_FEATURE_EDITING_HISTORY=256
CONFIG_BUSYBOX_DEFAULT_FEATURE_TAB_COMPLETION=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_EDITING_FANCY_PROMPT=y
CONFIG_BUSYBOX_DEFAULT_SUBST_WCHAR=0
CONFIG_BUSYBOX_DEFAULT_LAST_SUPPORTED_WCHAR=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_NON_POSIX_CP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_USE_SENDFILE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_COPYBUF_KB=4
CONFIG_BUSYBOX_DEFAULT_IOCTL_HEX2STR_ERROR=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SEAMLESS_GZ=y
CONFIG_BUSYBOX_DEFAULT_GUNZIP=y
CONFIG_BUSYBOX_DEFAULT_ZCAT=y
CONFIG_BUSYBOX_DEFAULT_BUNZIP2=y
CONFIG_BUSYBOX_DEFAULT_BZCAT=y
CONFIG_BUSYBOX_DEFAULT_BZIP2_SMALL=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_BZIP2_DECOMPRESS=y
CONFIG_BUSYBOX_DEFAULT_GZIP=y
CONFIG_BUSYBOX_DEFAULT_GZIP_FAST=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_GZIP_DECOMPRESS=y
CONFIG_BUSYBOX_DEFAULT_TAR=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TAR_CREATE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TAR_FROM=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TAR_GNU_EXTENSIONS=y
CONFIG_BUSYBOX_DEFAULT_BASENAME=y
CONFIG_BUSYBOX_DEFAULT_CAT=y
CONFIG_BUSYBOX_DEFAULT_CHGRP=y
CONFIG_BUSYBOX_DEFAULT_CHMOD=y
CONFIG_BUSYBOX_DEFAULT_CHOWN=y
CONFIG_BUSYBOX_DEFAULT_CHROOT=y
CONFIG_BUSYBOX_DEFAULT_CP=y
CONFIG_BUSYBOX_DEFAULT_CUT=y
CONFIG_BUSYBOX_DEFAULT_DATE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_DATE_ISOFMT=y
CONFIG_BUSYBOX_DEFAULT_DD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_DD_SIGNAL_HANDLING=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_DD_IBS_OBS=y
CONFIG_BUSYBOX_DEFAULT_DF=y
CONFIG_BUSYBOX_DEFAULT_DIRNAME=y
CONFIG_BUSYBOX_DEFAULT_DU=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
CONFIG_BUSYBOX_DEFAULT_ECHO=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FANCY_ECHO=y
CONFIG_BUSYBOX_DEFAULT_ENV=y
CONFIG_BUSYBOX_DEFAULT_EXPR=y
CONFIG_BUSYBOX_DEFAULT_EXPR_MATH_SUPPORT_64=y
CONFIG_BUSYBOX_DEFAULT_FALSE=y
CONFIG_BUSYBOX_DEFAULT_FSYNC=y
CONFIG_BUSYBOX_DEFAULT_HEAD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FANCY_HEAD=y
CONFIG_BUSYBOX_DEFAULT_ID=y
CONFIG_BUSYBOX_DEFAULT_LN=y
CONFIG_BUSYBOX_DEFAULT_LS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_FILETYPES=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_FOLLOWLINKS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_RECURSIVE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_WIDTH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_SORTFILES=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_TIMESTAMPS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_USERNAME=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_COLOR=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LS_COLOR_IS_DEFAULT=y
CONFIG_BUSYBOX_DEFAULT_MD5SUM=y
CONFIG_BUSYBOX_DEFAULT_SHA256SUM=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_MD5_SHA1_SUM_CHECK=y
CONFIG_BUSYBOX_DEFAULT_MKDIR=y
CONFIG_BUSYBOX_DEFAULT_MKFIFO=y
CONFIG_BUSYBOX_DEFAULT_MKNOD=y
CONFIG_BUSYBOX_DEFAULT_MKTEMP=y
CONFIG_BUSYBOX_DEFAULT_MV=y
CONFIG_BUSYBOX_DEFAULT_NICE=y
CONFIG_BUSYBOX_DEFAULT_PRINTF=y
CONFIG_BUSYBOX_DEFAULT_PWD=y
CONFIG_BUSYBOX_DEFAULT_READLINK=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_READLINK_FOLLOW=y
CONFIG_BUSYBOX_DEFAULT_RM=y
CONFIG_BUSYBOX_DEFAULT_RMDIR=y
CONFIG_BUSYBOX_DEFAULT_SEQ=y
CONFIG_BUSYBOX_DEFAULT_SLEEP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FANCY_SLEEP=y
CONFIG_BUSYBOX_DEFAULT_SORT=y
CONFIG_BUSYBOX_DEFAULT_SYNC=y
CONFIG_BUSYBOX_DEFAULT_TAIL=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FANCY_TAIL=y
CONFIG_BUSYBOX_DEFAULT_TEE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TEE_USE_BLOCK_IO=y
CONFIG_BUSYBOX_DEFAULT_TEST=y
CONFIG_BUSYBOX_DEFAULT_TEST1=y
CONFIG_BUSYBOX_DEFAULT_TEST2=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TEST_64=y
CONFIG_BUSYBOX_DEFAULT_TOUCH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TOUCH_SUSV3=y
CONFIG_BUSYBOX_DEFAULT_TR=y
CONFIG_BUSYBOX_DEFAULT_TRUE=y
CONFIG_BUSYBOX_DEFAULT_UNAME=y
CONFIG_BUSYBOX_DEFAULT_UNAME_OSNAME=“GNU/Linux”
CONFIG_BUSYBOX_DEFAULT_UNIQ=y
CONFIG_BUSYBOX_DEFAULT_WC=y
CONFIG_BUSYBOX_DEFAULT_YES=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_PRESERVE_HARDLINKS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_HUMAN_READABLE=y
CONFIG_BUSYBOX_DEFAULT_CLEAR=y
CONFIG_BUSYBOX_DEFAULT_DEFAULT_SETFONT_DIR=“”
CONFIG_BUSYBOX_DEFAULT_RESET=y
CONFIG_BUSYBOX_DEFAULT_START_STOP_DAEMON=y
CONFIG_BUSYBOX_DEFAULT_WHICH=y
CONFIG_BUSYBOX_DEFAULT_AWK=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_AWK_LIBM=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_AWK_GNU_EXTENSIONS=y
CONFIG_BUSYBOX_DEFAULT_CMP=y
CONFIG_BUSYBOX_DEFAULT_SED=y
CONFIG_BUSYBOX_DEFAULT_VI=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_MAX_LEN=1024
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_COLON=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_YANKMARK=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_SEARCH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_USE_SIGNALS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_DOT_CMD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_READONLY=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_SETOPTS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_SET=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_WIN_RESIZE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_ASK_TERMINAL=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_VI_UNDO_QUEUE_MAX=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_ALLOW_EXEC=y
CONFIG_BUSYBOX_DEFAULT_FIND=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_PRINT0=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_MTIME=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_PERM=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_TYPE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_XDEV=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_MAXDEPTH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_NEWER=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_EXEC=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_USER=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_GROUP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_NOT=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_DEPTH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_PAREN=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_SIZE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_PRUNE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_PATH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FIND_REGEX=y
CONFIG_BUSYBOX_DEFAULT_GREP=y
CONFIG_BUSYBOX_DEFAULT_EGREP=y
CONFIG_BUSYBOX_DEFAULT_FGREP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_GREP_CONTEXT=y
CONFIG_BUSYBOX_DEFAULT_XARGS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_XARGS_SUPPORT_QUOTES=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_XARGS_SUPPORT_TERMOPT=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
CONFIG_BUSYBOX_DEFAULT_HALT=y
CONFIG_BUSYBOX_DEFAULT_POWEROFF=y
CONFIG_BUSYBOX_DEFAULT_REBOOT=y
CONFIG_BUSYBOX_DEFAULT_TELINIT_PATH=“”
CONFIG_BUSYBOX_DEFAULT_FEATURE_KILL_DELAY=0
CONFIG_BUSYBOX_DEFAULT_INIT_TERMINAL_TYPE=“”
CONFIG_BUSYBOX_DEFAULT_FEATURE_SHADOWPASSWDS=y
CONFIG_BUSYBOX_DEFAULT_LAST_ID=0
CONFIG_BUSYBOX_DEFAULT_FIRST_SYSTEM_ID=0
CONFIG_BUSYBOX_DEFAULT_LAST_SYSTEM_ID=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_DEFAULT_PASSWD_ALGO=“md5”
CONFIG_BUSYBOX_DEFAULT_LOGIN=y
CONFIG_BUSYBOX_DEFAULT_LOGIN_SESSION_AS_CHILD=y
CONFIG_BUSYBOX_DEFAULT_PASSWD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_PASSWD_WEAK_CHECK=y
CONFIG_BUSYBOX_DEFAULT_DEFAULT_MODULES_DIR=“”
CONFIG_BUSYBOX_DEFAULT_DEFAULT_DEPMOD_FILE=“”
CONFIG_BUSYBOX_DEFAULT_DMESG=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_DMESG_PRETTY=y
CONFIG_BUSYBOX_DEFAULT_FLOCK=y
CONFIG_BUSYBOX_DEFAULT_HEXDUMP=y
CONFIG_BUSYBOX_DEFAULT_HWCLOCK=y
CONFIG_BUSYBOX_DEFAULT_MKSWAP=y
CONFIG_BUSYBOX_DEFAULT_MOUNT=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_MOUNT_HELPERS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_MOUNT_CIFS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_MOUNT_FLAGS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_MOUNT_FSTAB=y
CONFIG_BUSYBOX_DEFAULT_PIVOT_ROOT=y
CONFIG_BUSYBOX_DEFAULT_SWAPON=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SWAPON_DISCARD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SWAPON_PRI=y
CONFIG_BUSYBOX_DEFAULT_SWAPOFF=y
CONFIG_BUSYBOX_DEFAULT_SWITCH_ROOT=y
CONFIG_BUSYBOX_DEFAULT_UMOUNT=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_UMOUNT_ALL=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_MOUNT_LOOP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_BEEP_FREQ=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_BEEP_LENGTH_MS=0
CONFIG_BUSYBOX_DEFAULT_CROND=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_CROND_DIR=“/etc”
CONFIG_BUSYBOX_DEFAULT_CRONTAB=y
CONFIG_BUSYBOX_DEFAULT_LESS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_LESS_MAXLINES=9999999
CONFIG_BUSYBOX_DEFAULT_LOCK=y
CONFIG_BUSYBOX_DEFAULT_STRINGS=y
CONFIG_BUSYBOX_DEFAULT_TIME=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IPV6=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_PREFER_IPV4_ADDRESS=y
CONFIG_BUSYBOX_DEFAULT_VERBOSE_RESOLUTION_ERRORS=y
CONFIG_BUSYBOX_DEFAULT_BRCTL=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_BRCTL_FANCY=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_BRCTL_SHOW=y
CONFIG_BUSYBOX_DEFAULT_IFCONFIG=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IFCONFIG_STATUS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IFCONFIG_HW=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IFCONFIG_BROADCAST_PLUS=y
CONFIG_BUSYBOX_DEFAULT_IFUPDOWN_IFSTATE_PATH=“”
CONFIG_BUSYBOX_DEFAULT_IP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IP_ADDRESS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IP_LINK=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IP_ROUTE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IP_ROUTE_DIR=“/etc/iproute2”
CONFIG_BUSYBOX_DEFAULT_FEATURE_IP_RULE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_IP_NEIGH=y
CONFIG_BUSYBOX_DEFAULT_NC=y
CONFIG_BUSYBOX_DEFAULT_NETMSG=y
CONFIG_BUSYBOX_DEFAULT_NETSTAT=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_NETSTAT_WIDE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_NETSTAT_PRG=y
CONFIG_BUSYBOX_DEFAULT_NSLOOKUP_OPENWRT=y
CONFIG_BUSYBOX_DEFAULT_NTPD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_NTPD_SERVER=y
CONFIG_BUSYBOX_DEFAULT_PING=y
CONFIG_BUSYBOX_DEFAULT_PING6=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_FANCY_PING=y
CONFIG_BUSYBOX_DEFAULT_ROUTE=y
CONFIG_BUSYBOX_DEFAULT_TRACEROUTE=y
CONFIG_BUSYBOX_DEFAULT_TRACEROUTE6=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TRACEROUTE_VERBOSE=y
CONFIG_BUSYBOX_DEFAULT_DHCPD_LEASES_FILE=“”
CONFIG_BUSYBOX_DEFAULT_UDHCPC=y
CONFIG_BUSYBOX_DEFAULT_UDHCPC_DEFAULT_SCRIPT=“/usr/share/udhcpc/default.script”
CONFIG_BUSYBOX_DEFAULT_UDHCP_DEBUG=0
CONFIG_BUSYBOX_DEFAULT_UDHCPC_SLACK_FOR_BUGGY_SERVERS=80
CONFIG_BUSYBOX_DEFAULT_FEATURE_UDHCP_RFC3397=y
CONFIG_BUSYBOX_DEFAULT_IFUPDOWN_UDHCPC_CMD_OPTIONS=“”
CONFIG_BUSYBOX_DEFAULT_FEATURE_MIME_CHARSET=“”
CONFIG_BUSYBOX_DEFAULT_FREE=y
CONFIG_BUSYBOX_DEFAULT_KILL=y
CONFIG_BUSYBOX_DEFAULT_KILLALL=y
CONFIG_BUSYBOX_DEFAULT_PGREP=y
CONFIG_BUSYBOX_DEFAULT_PIDOF=y
CONFIG_BUSYBOX_DEFAULT_PS=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_PS_WIDE=y
CONFIG_BUSYBOX_DEFAULT_BB_SYSCTL=y
CONFIG_BUSYBOX_DEFAULT_TOP=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
CONFIG_BUSYBOX_DEFAULT_UPTIME=y
CONFIG_BUSYBOX_DEFAULT_SV_DEFAULT_SERVICE_DIR=“”
CONFIG_BUSYBOX_DEFAULT_SH_IS_ASH=y
CONFIG_BUSYBOX_DEFAULT_BASH_IS_NONE=y
CONFIG_BUSYBOX_DEFAULT_ASH=y
CONFIG_BUSYBOX_DEFAULT_ASH_INTERNAL_GLOB=y
CONFIG_BUSYBOX_DEFAULT_ASH_BASH_COMPAT=y
CONFIG_BUSYBOX_DEFAULT_ASH_JOB_CONTROL=y
CONFIG_BUSYBOX_DEFAULT_ASH_ALIAS=y
CONFIG_BUSYBOX_DEFAULT_ASH_EXPAND_PRMT=y
CONFIG_BUSYBOX_DEFAULT_ASH_ECHO=y
CONFIG_BUSYBOX_DEFAULT_ASH_PRINTF=y
CONFIG_BUSYBOX_DEFAULT_ASH_TEST=y
CONFIG_BUSYBOX_DEFAULT_ASH_GETOPTS=y
CONFIG_BUSYBOX_DEFAULT_ASH_CMDCMD=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SH_MATH=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SH_MATH_64=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SH_NOFORK=y
CONFIG_BUSYBOX_DEFAULT_LOGGER=y
CONFIG_BUSYBOX_DEFAULT_FEATURE_SYSLOGD_READ_BUFFER_SIZE=0
CONFIG_BUSYBOX_DEFAULT_FEATURE_IPC_SYSLOG_BUFFER_SIZE=0
CONFIG_BUSYBOX_CONFIG_HAVE_DOT_CONFIG=y
CONFIG_BUSYBOX_CONFIG_INCLUDE_SUSv2=y
CONFIG_BUSYBOX_CONFIG_LONG_OPTS=y
CONFIG_BUSYBOX_CONFIG_SHOW_USAGE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VERBOSE_USAGE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_COMPRESS_USAGE=y
CONFIG_BUSYBOX_CONFIG_LFS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DEVPTS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_PIDFILE=y
CONFIG_BUSYBOX_CONFIG_PID_FILE_PATH=“/var/run”
CONFIG_BUSYBOX_CONFIG_FEATURE_SUID=y
Thank you,
Too many lines for the forum software so I’ve had to split it
CONFIG_BUSYBOX_CONFIG_FEATURE_PREFER_APPLETS=y
CONFIG_BUSYBOX_CONFIG_BUSYBOX_EXEC_PATH=“/proc/self/exe”
CONFIG_BUSYBOX_CONFIG_FEATURE_SYSLOG=y
CONFIG_BUSYBOX_CONFIG_PLATFORM_LINUX=y
CONFIG_BUSYBOX_CONFIG_CROSS_COMPILER_PREFIX=“”
CONFIG_BUSYBOX_CONFIG_SYSROOT=“”
CONFIG_BUSYBOX_CONFIG_EXTRA_CFLAGS=“”
CONFIG_BUSYBOX_CONFIG_EXTRA_LDFLAGS=“”
CONFIG_BUSYBOX_CONFIG_EXTRA_LDLIBS=“”
CONFIG_BUSYBOX_CONFIG_INSTALL_APPLET_SYMLINKS=y
CONFIG_BUSYBOX_CONFIG_PREFIX=“./_install”
CONFIG_BUSYBOX_CONFIG_NO_DEBUG_LIB=y
CONFIG_BUSYBOX_CONFIG_FLOAT_DURATION=y
CONFIG_BUSYBOX_CONFIG_FEATURE_BUFFERS_GO_ON_STACK=y
CONFIG_BUSYBOX_CONFIG_PASSWORD_MINLEN=6
CONFIG_BUSYBOX_CONFIG_MD5_SMALL=1
CONFIG_BUSYBOX_CONFIG_SHA3_SMALL=1
CONFIG_BUSYBOX_CONFIG_FEATURE_FAST_TOP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_EDITING=y
CONFIG_BUSYBOX_CONFIG_FEATURE_EDITING_MAX_LEN=512
CONFIG_BUSYBOX_CONFIG_FEATURE_EDITING_HISTORY=256
CONFIG_BUSYBOX_CONFIG_FEATURE_TAB_COMPLETION=y
CONFIG_BUSYBOX_CONFIG_FEATURE_EDITING_FANCY_PROMPT=y
CONFIG_BUSYBOX_CONFIG_UNICODE_SUPPORT=y
CONFIG_BUSYBOX_CONFIG_SUBST_WCHAR=0
CONFIG_BUSYBOX_CONFIG_LAST_SUPPORTED_WCHAR=0
CONFIG_BUSYBOX_CONFIG_UNICODE_COMBINING_WCHARS=y
CONFIG_BUSYBOX_CONFIG_UNICODE_WIDE_WCHARS=y
CONFIG_BUSYBOX_CONFIG_UNICODE_BIDI_SUPPORT=y
CONFIG_BUSYBOX_CONFIG_UNICODE_NEUTRAL_TABLE=y
CONFIG_BUSYBOX_CONFIG_UNICODE_PRESERVE_BROKEN=y
CONFIG_BUSYBOX_CONFIG_FEATURE_NON_POSIX_CP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_USE_SENDFILE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_COPYBUF_KB=4
CONFIG_BUSYBOX_CONFIG_IOCTL_HEX2STR_ERROR=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SEAMLESS_GZ=y
CONFIG_BUSYBOX_CONFIG_GUNZIP=y
CONFIG_BUSYBOX_CONFIG_ZCAT=y
CONFIG_BUSYBOX_CONFIG_BUNZIP2=y
CONFIG_BUSYBOX_CONFIG_BZCAT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_BZIP2_DECOMPRESS=y
CONFIG_BUSYBOX_CONFIG_GZIP=y
CONFIG_BUSYBOX_CONFIG_GZIP_FAST=0
CONFIG_BUSYBOX_CONFIG_FEATURE_GZIP_DECOMPRESS=y
CONFIG_BUSYBOX_CONFIG_TAR=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TAR_CREATE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TAR_FROM=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TAR_GNU_EXTENSIONS=y
CONFIG_BUSYBOX_CONFIG_BASENAME=y
CONFIG_BUSYBOX_CONFIG_CAT=y
CONFIG_BUSYBOX_CONFIG_CHGRP=y
CONFIG_BUSYBOX_CONFIG_CHMOD=y
CONFIG_BUSYBOX_CONFIG_CHOWN=y
CONFIG_BUSYBOX_CONFIG_CHROOT=y
CONFIG_BUSYBOX_CONFIG_CP=y
CONFIG_BUSYBOX_CONFIG_CUT=y
CONFIG_BUSYBOX_CONFIG_DATE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DATE_ISOFMT=y
CONFIG_BUSYBOX_CONFIG_DD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DD_SIGNAL_HANDLING=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DD_IBS_OBS=y
CONFIG_BUSYBOX_CONFIG_DF=y
CONFIG_BUSYBOX_CONFIG_DIRNAME=y
CONFIG_BUSYBOX_CONFIG_DU=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
CONFIG_BUSYBOX_CONFIG_ECHO=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FANCY_ECHO=y
CONFIG_BUSYBOX_CONFIG_ENV=y
CONFIG_BUSYBOX_CONFIG_EXPR=y
CONFIG_BUSYBOX_CONFIG_EXPR_MATH_SUPPORT_64=y
CONFIG_BUSYBOX_CONFIG_FALSE=y
CONFIG_BUSYBOX_CONFIG_FSYNC=y
CONFIG_BUSYBOX_CONFIG_HEAD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FANCY_HEAD=y
CONFIG_BUSYBOX_CONFIG_ID=y
CONFIG_BUSYBOX_CONFIG_LN=y
CONFIG_BUSYBOX_CONFIG_LS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_FILETYPES=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_FOLLOWLINKS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_RECURSIVE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_WIDTH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_SORTFILES=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_TIMESTAMPS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_USERNAME=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_COLOR=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LS_COLOR_IS_DEFAULT=y
CONFIG_BUSYBOX_CONFIG_MD5SUM=y
CONFIG_BUSYBOX_CONFIG_SHA256SUM=y
CONFIG_BUSYBOX_CONFIG_FEATURE_MD5_SHA1_SUM_CHECK=y
CONFIG_BUSYBOX_CONFIG_MKDIR=y
CONFIG_BUSYBOX_CONFIG_MKFIFO=y
CONFIG_BUSYBOX_CONFIG_MKNOD=y
CONFIG_BUSYBOX_CONFIG_MKTEMP=y
CONFIG_BUSYBOX_CONFIG_MV=y
CONFIG_BUSYBOX_CONFIG_NICE=y
CONFIG_BUSYBOX_CONFIG_PRINTF=y
CONFIG_BUSYBOX_CONFIG_PWD=y
CONFIG_BUSYBOX_CONFIG_READLINK=y
CONFIG_BUSYBOX_CONFIG_FEATURE_READLINK_FOLLOW=y
CONFIG_BUSYBOX_CONFIG_RM=y
CONFIG_BUSYBOX_CONFIG_RMDIR=y
CONFIG_BUSYBOX_CONFIG_SEQ=y
CONFIG_BUSYBOX_CONFIG_SLEEP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FANCY_SLEEP=y
CONFIG_BUSYBOX_CONFIG_SORT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FLOAT_SLEEP=y
CONFIG_BUSYBOX_CONFIG_SYNC=y
CONFIG_BUSYBOX_CONFIG_TAIL=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FANCY_TAIL=y
CONFIG_BUSYBOX_CONFIG_TEE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TEE_USE_BLOCK_IO=y
CONFIG_BUSYBOX_CONFIG_TEST=y
CONFIG_BUSYBOX_CONFIG_TEST1=y
CONFIG_BUSYBOX_CONFIG_TEST2=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TEST_64=y
CONFIG_BUSYBOX_CONFIG_TIMEOUT=y
CONFIG_BUSYBOX_CONFIG_TOUCH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TOUCH_SUSV3=y
CONFIG_BUSYBOX_CONFIG_TR=y
CONFIG_BUSYBOX_CONFIG_TRUE=y
CONFIG_BUSYBOX_CONFIG_UNAME=y
CONFIG_BUSYBOX_CONFIG_UNAME_OSNAME=“GNU/Linux”
CONFIG_BUSYBOX_CONFIG_UNIQ=y
CONFIG_BUSYBOX_CONFIG_USLEEP=y
CONFIG_BUSYBOX_CONFIG_WC=y
CONFIG_BUSYBOX_CONFIG_YES=y
CONFIG_BUSYBOX_CONFIG_FEATURE_PRESERVE_HARDLINKS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_HUMAN_READABLE=y
CONFIG_BUSYBOX_CONFIG_CLEAR=y
CONFIG_BUSYBOX_CONFIG_RESET=y
CONFIG_BUSYBOX_CONFIG_START_STOP_DAEMON=y
CONFIG_BUSYBOX_CONFIG_WHICH=y
CONFIG_BUSYBOX_CONFIG_AWK=y
CONFIG_BUSYBOX_CONFIG_FEATURE_AWK_LIBM=y
CONFIG_BUSYBOX_CONFIG_FEATURE_AWK_GNU_EXTENSIONS=y
CONFIG_BUSYBOX_CONFIG_CMP=y
CONFIG_BUSYBOX_CONFIG_SED=y
CONFIG_BUSYBOX_CONFIG_VI=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_MAX_LEN=1024
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_COLON=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_YANKMARK=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_SEARCH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_USE_SIGNALS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_DOT_CMD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_READONLY=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_SETOPTS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_SET=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_WIN_RESIZE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_VI_ASK_TERMINAL=y
CONFIG_BUSYBOX_CONFIG_FEATURE_ALLOW_EXEC=y
CONFIG_BUSYBOX_CONFIG_FIND=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_PRINT0=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_MTIME=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_PERM=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_TYPE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_XDEV=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_MAXDEPTH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_NEWER=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_EXEC=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_USER=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_GROUP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_NOT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_DEPTH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_PAREN=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_SIZE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_PRUNE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_PATH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FIND_REGEX=y
CONFIG_BUSYBOX_CONFIG_GREP=y
CONFIG_BUSYBOX_CONFIG_EGREP=y
CONFIG_BUSYBOX_CONFIG_FGREP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_GREP_CONTEXT=y
CONFIG_BUSYBOX_CONFIG_XARGS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
CONFIG_BUSYBOX_CONFIG_FEATURE_XARGS_SUPPORT_QUOTES=y
CONFIG_BUSYBOX_CONFIG_FEATURE_XARGS_SUPPORT_TERMOPT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
CONFIG_BUSYBOX_CONFIG_HALT=y
CONFIG_BUSYBOX_CONFIG_POWEROFF=y
CONFIG_BUSYBOX_CONFIG_REBOOT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SHADOWPASSWDS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DEFAULT_PASSWD_ALGO=“md5”
CONFIG_BUSYBOX_CONFIG_LOGIN=y
CONFIG_BUSYBOX_CONFIG_PASSWD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_PASSWD_WEAK_CHECK=y
CONFIG_BUSYBOX_CONFIG_DMESG=y
CONFIG_BUSYBOX_CONFIG_FEATURE_DMESG_PRETTY=y
CONFIG_BUSYBOX_CONFIG_FLOCK=y
CONFIG_BUSYBOX_CONFIG_HEXDUMP=y
CONFIG_BUSYBOX_CONFIG_HWCLOCK=y
CONFIG_BUSYBOX_CONFIG_IPCRM=y
CONFIG_BUSYBOX_CONFIG_IPCS=y
CONFIG_BUSYBOX_CONFIG_MKSWAP=y
CONFIG_BUSYBOX_CONFIG_MOUNT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_MOUNT_HELPERS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_MOUNT_CIFS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_MOUNT_FLAGS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_MOUNT_FSTAB=y
CONFIG_BUSYBOX_CONFIG_PIVOT_ROOT=y
CONFIG_BUSYBOX_CONFIG_SWAPON=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SWAPON_DISCARD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SWAPON_PRI=y
CONFIG_BUSYBOX_CONFIG_SWAPOFF=y
CONFIG_BUSYBOX_CONFIG_SWITCH_ROOT=y
CONFIG_BUSYBOX_CONFIG_UMOUNT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_UMOUNT_ALL=y
CONFIG_BUSYBOX_CONFIG_FEATURE_MOUNT_LOOP=y
CONFIG_BUSYBOX_CONFIG_CROND=y
CONFIG_BUSYBOX_CONFIG_FEATURE_CROND_DIR=“/etc”
CONFIG_BUSYBOX_CONFIG_CRONTAB=y
CONFIG_BUSYBOX_CONFIG_I2CSET=y
CONFIG_BUSYBOX_CONFIG_LESS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_LESS_MAXLINES=9999999
CONFIG_BUSYBOX_CONFIG_LOCK=y
CONFIG_BUSYBOX_CONFIG_STRINGS=y
CONFIG_BUSYBOX_CONFIG_TIME=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IPV6=y
CONFIG_BUSYBOX_CONFIG_FEATURE_PREFER_IPV4_ADDRESS=y
CONFIG_BUSYBOX_CONFIG_VERBOSE_RESOLUTION_ERRORS=y
CONFIG_BUSYBOX_CONFIG_BRCTL=y
CONFIG_BUSYBOX_CONFIG_FEATURE_BRCTL_FANCY=y
CONFIG_BUSYBOX_CONFIG_FEATURE_BRCTL_SHOW=y
CONFIG_BUSYBOX_CONFIG_IFCONFIG=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IFCONFIG_STATUS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IFCONFIG_HW=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IFCONFIG_BROADCAST_PLUS=y
CONFIG_BUSYBOX_CONFIG_IP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IP_ADDRESS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IP_LINK=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IP_ROUTE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IP_ROUTE_DIR=“/etc/iproute2”
CONFIG_BUSYBOX_CONFIG_FEATURE_IP_RULE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_IP_NEIGH=y
CONFIG_BUSYBOX_CONFIG_NC=y
CONFIG_BUSYBOX_CONFIG_NC_SERVER=y
CONFIG_BUSYBOX_CONFIG_NC_EXTRA=y
CONFIG_BUSYBOX_CONFIG_NC_110_COMPAT=y
CONFIG_BUSYBOX_CONFIG_NETMSG=y
CONFIG_BUSYBOX_CONFIG_NETSTAT=y
CONFIG_BUSYBOX_CONFIG_FEATURE_NETSTAT_WIDE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_NETSTAT_PRG=y
CONFIG_BUSYBOX_CONFIG_NSLOOKUP_OPENWRT=y
CONFIG_BUSYBOX_CONFIG_NTPD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_NTPD_SERVER=y
CONFIG_BUSYBOX_CONFIG_PING=y
CONFIG_BUSYBOX_CONFIG_PING6=y
CONFIG_BUSYBOX_CONFIG_FEATURE_FANCY_PING=y
CONFIG_BUSYBOX_CONFIG_ROUTE=y
CONFIG_BUSYBOX_CONFIG_TRACEROUTE=y
CONFIG_BUSYBOX_CONFIG_TRACEROUTE6=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TRACEROUTE_VERBOSE=y
CONFIG_BUSYBOX_CONFIG_UDHCPC=y
CONFIG_BUSYBOX_CONFIG_UDHCPC_DEFAULT_SCRIPT=“/usr/share/udhcpc/default.script”
CONFIG_BUSYBOX_CONFIG_UDHCP_DEBUG=0
CONFIG_BUSYBOX_CONFIG_UDHCPC_SLACK_FOR_BUGGY_SERVERS=80
CONFIG_BUSYBOX_CONFIG_FEATURE_UDHCP_RFC3397=y
CONFIG_BUSYBOX_CONFIG_FREE=y
CONFIG_BUSYBOX_CONFIG_FUSER=y
CONFIG_BUSYBOX_CONFIG_KILL=y
CONFIG_BUSYBOX_CONFIG_KILLALL=y
CONFIG_BUSYBOX_CONFIG_PGREP=y
CONFIG_BUSYBOX_CONFIG_PIDOF=y
CONFIG_BUSYBOX_CONFIG_PS=y
CONFIG_BUSYBOX_CONFIG_FEATURE_PS_WIDE=y
CONFIG_BUSYBOX_CONFIG_BB_SYSCTL=y
CONFIG_BUSYBOX_CONFIG_TOP=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
CONFIG_BUSYBOX_CONFIG_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
CONFIG_BUSYBOX_CONFIG_UPTIME=y
CONFIG_BUSYBOX_CONFIG_SH_IS_ASH=y
CONFIG_BUSYBOX_CONFIG_BASH_IS_NONE=y
CONFIG_BUSYBOX_CONFIG_ASH=y
CONFIG_BUSYBOX_CONFIG_ASH_INTERNAL_GLOB=y
CONFIG_BUSYBOX_CONFIG_ASH_BASH_COMPAT=y
CONFIG_BUSYBOX_CONFIG_ASH_JOB_CONTROL=y
CONFIG_BUSYBOX_CONFIG_ASH_ALIAS=y
CONFIG_BUSYBOX_CONFIG_ASH_EXPAND_PRMT=y
CONFIG_BUSYBOX_CONFIG_ASH_ECHO=y
CONFIG_BUSYBOX_CONFIG_ASH_PRINTF=y
CONFIG_BUSYBOX_CONFIG_ASH_TEST=y
CONFIG_BUSYBOX_CONFIG_ASH_GETOPTS=y
CONFIG_BUSYBOX_CONFIG_ASH_CMDCMD=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SH_MATH=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SH_MATH_64=y
CONFIG_BUSYBOX_CONFIG_FEATURE_SH_NOFORK=y
CONFIG_BUSYBOX_CONFIG_LOGGER=y
CONFIG_PACKAGE_ca-bundle=y
CONFIG_PACKAGE_dnsmasq=y
CONFIG_PACKAGE_dropbear=y
CONFIG_DROPBEAR_CURVE25519=y
CONFIG_DROPBEAR_DBCLIENT=y
CONFIG_PACKAGE_firewall=y
CONFIG_PACKAGE_fstools=y
CONFIG_FSTOOLS_UBIFS_EXTROOT=y
CONFIG_PACKAGE_fwtool=y
CONFIG_PACKAGE_getrandom=y
CONFIG_PACKAGE_jsonfilter=y
CONFIG_PACKAGE_libc=y
CONFIG_PACKAGE_libgcc=y
CONFIG_PACKAGE_libpthread=y
CONFIG_PACKAGE_librt=y
CONFIG_PACKAGE_libstdcpp=y
CONFIG_PACKAGE_logd=y
CONFIG_PACKAGE_mtd=y
CONFIG_PACKAGE_netifd=y
CONFIG_PACKAGE_openwrt-keyring=y
CONFIG_PACKAGE_opkg=y
CONFIG_PACKAGE_procd=y
CONFIG_PACKAGE_ubox=y
CONFIG_PACKAGE_ubus=y
CONFIG_PACKAGE_ubusd=y
CONFIG_PACKAGE_uci=y
CONFIG_PACKAGE_urandom-seed=y
CONFIG_PACKAGE_urngd=y
CONFIG_PACKAGE_usign=y
CONFIG_ZABBIX_NOSSL=y
CONFIG_ZABBIX_POSTGRESQL=y
CONFIG_PACKAGE_rt2800-usb-firmware=y
CONFIG_PACKAGE_wireless-regdb=y
CONFIG_PACKAGE_kmod-scsi-core=y
CONFIG_PACKAGE_kmod-crypto-aead=y
CONFIG_PACKAGE_kmod-crypto-crc32c=y
CONFIG_PACKAGE_kmod-crypto-ecb=y
CONFIG_PACKAGE_kmod-crypto-hash=y
CONFIG_PACKAGE_kmod-crypto-manager=y
CONFIG_PACKAGE_kmod-crypto-null=y
CONFIG_PACKAGE_kmod-crypto-pcompress=y
CONFIG_PACKAGE_kmod-crypto-sha1=y
CONFIG_PACKAGE_kmod-fs-configfs=y
CONFIG_PACKAGE_kmod-fs-exfat=y
CONFIG_PACKAGE_kmod-fs-ext4=y
CONFIG_PACKAGE_kmod-fs-ntfs=y
CONFIG_PACKAGE_kmod-fs-vfat=y
CONFIG_PACKAGE_kmod-fuse=y
CONFIG_PACKAGE_kmod-lib-crc-ccitt=y
CONFIG_PACKAGE_kmod-lib-crc16=y
CONFIG_PACKAGE_kmod-lib-textsearch=y
CONFIG_PACKAGE_kmod-nls-base=y
CONFIG_PACKAGE_kmod-nls-cp437=y
CONFIG_PACKAGE_kmod-nls-iso8859-1=y
CONFIG_PACKAGE_kmod-nls-utf8=y
CONFIG_PACKAGE_kmod-ip6tables=y
CONFIG_PACKAGE_kmod-ipt-conntrack=y
CONFIG_PACKAGE_kmod-ipt-conntrack-extra=y
CONFIG_PACKAGE_kmod-ipt-core=y
CONFIG_PACKAGE_kmod-ipt-ipopt=y
CONFIG_PACKAGE_kmod-ipt-ipset=y
CONFIG_PACKAGE_kmod-ipt-nat=y
CONFIG_PACKAGE_kmod-ipt-offload=y
CONFIG_PACKAGE_kmod-ipt-raw=y
CONFIG_PACKAGE_kmod-nf-conntrack=y
CONFIG_PACKAGE_kmod-nf-conntrack-netlink=y
CONFIG_PACKAGE_kmod-nf-conntrack6=y
CONFIG_PACKAGE_kmod-nf-flow=y
CONFIG_PACKAGE_kmod-nf-ipt=y
CONFIG_PACKAGE_kmod-nf-ipt6=y
CONFIG_PACKAGE_kmod-nf-nat=y
CONFIG_PACKAGE_kmod-nf-nathelper-extra=y
CONFIG_PACKAGE_kmod-nf-reject=y
CONFIG_PACKAGE_kmod-nf-reject6=y
CONFIG_PACKAGE_kmod-nfnetlink=y
CONFIG_PACKAGE_kmod-libphy=y
CONFIG_PACKAGE_kmod-mii=y
CONFIG_PACKAGE_kmod-swconfig=y
CONFIG_PACKAGE_kmod-switch-mvsw61xx=y
CONFIG_PACKAGE_kmod-ppp=y
CONFIG_PACKAGE_kmod-mppe=y
CONFIG_PACKAGE_kmod-pppoe=y
CONFIG_PACKAGE_kmod-pppox=y
CONFIG_PACKAGE_kmod-slhc=y
CONFIG_PACKAGE_kmod-tun=y
CONFIG_PACKAGE_kmod-gpio-button-hotplug=y
CONFIG_PACKAGE_kmod-usb-core=y
CONFIG_PACKAGE_kmod-usb-ehci=y
CONFIG_PACKAGE_kmod-usb-gadget=y
CONFIG_PACKAGE_kmod-usb-gadget-eth=y
CONFIG_PACKAGE_kmod-usb-gadget-mass-storage=y
CONFIG_PACKAGE_kmod-usb-lib-composite=y
CONFIG_PACKAGE_kmod-usb-net=y
CONFIG_PACKAGE_kmod-usb-net-cdc-ether=y
CONFIG_PACKAGE_kmod-usb-net-ipheth=y
CONFIG_PACKAGE_kmod-usb-net-pl=y
CONFIG_PACKAGE_kmod-usb-net-qmi-wwan=y
CONFIG_PACKAGE_kmod-usb-net-rndis=y
CONFIG_PACKAGE_kmod-usb-ohci=y
CONFIG_PACKAGE_kmod-usb-serial=y
CONFIG_PACKAGE_kmod-usb-serial-cp210x=y
CONFIG_PACKAGE_kmod-usb-serial-ftdi=m
CONFIG_PACKAGE_kmod-usb-serial-option=y
CONFIG_PACKAGE_kmod-usb-serial-pl2303=m
CONFIG_PACKAGE_kmod-usb-serial-sierrawireless=y
CONFIG_PACKAGE_kmod-usb-serial-wwan=y
CONFIG_PACKAGE_kmod-usb-storage=y
CONFIG_PACKAGE_kmod-usb-uhci=y
CONFIG_PACKAGE_kmod-usb-wdm=y
CONFIG_PACKAGE_kmod-usb2=y
CONFIG_PACKAGE_kmod-usb3=y
CONFIG_PACKAGE_kmod-cfg80211=y
CONFIG_PACKAGE_kmod-mac80211=y
CONFIG_PACKAGE_MAC80211_DEBUGFS=y
CONFIG_PACKAGE_MAC80211_MESH=y
CONFIG_PACKAGE_kmod-rt2800-lib=y
CONFIG_PACKAGE_kmod-rt2800-usb=y
CONFIG_PACKAGE_kmod-rt2x00-lib=y
CONFIG_PACKAGE_kmod-rt2x00-usb=y
CONFIG_PACKAGE_python=y
CONFIG_PACKAGE_python-base=y
CONFIG_PACKAGE_python-codecs=y
CONFIG_PACKAGE_python-compiler=y
CONFIG_PACKAGE_python-ctypes=y
CONFIG_PACKAGE_python-db=y
CONFIG_PACKAGE_python-decimal=y
CONFIG_PACKAGE_python-distutils=y
CONFIG_PACKAGE_python-email=y
CONFIG_PACKAGE_python-gdbm=y
CONFIG_PACKAGE_python-light=y
CONFIG_PACKAGE_python-logging=y
CONFIG_PACKAGE_python-multiprocessing=y
CONFIG_PACKAGE_python-ncurses=y
CONFIG_PACKAGE_python-openssl=y
CONFIG_PACKAGE_python-pydoc=y
CONFIG_PACKAGE_python-sqlite3=y
CONFIG_PACKAGE_python-unittest=y
CONFIG_PACKAGE_python-xml=y
CONFIG_PACKAGE_libbz2=y
CONFIG_PACKAGE_libip4tc=y
CONFIG_PACKAGE_libip6tc=y
CONFIG_PACKAGE_libxtables=y
CONFIG_PACKAGE_libyaml=y
CONFIG_PACKAGE_libopenssl=y
CONFIG_OPENSSL_WITH_ASM=y
CONFIG_OPENSSL_WITH_DEPRECATED=y
CONFIG_OPENSSL_WITH_ERROR_MESSAGES=y
CONFIG_OPENSSL_WITH_TLS13=y
CONFIG_OPENSSL_WITH_SRP=y
CONFIG_OPENSSL_WITH_CMS=y
CONFIG_OPENSSL_WITH_CHACHA_POLY1305=y
CONFIG_OPENSSL_WITH_PSK=y
CONFIG_OPENSSL_ENGINE=y
CONFIG_PACKAGE_libsqlite3=y
CONFIG_SQLITE3_DYNAMIC_EXTENSIONS=y
CONFIG_SQLITE3_FTS3=y
CONFIG_SQLITE3_FTS4=y
CONFIG_SQLITE3_FTS5=y
CONFIG_SQLITE3_JSON1=y
CONFIG_SQLITE3_RTREE=y
CONFIG_PACKAGE_libimobiledevice=y
CONFIG_PACKAGE_libplist=y
CONFIG_PACKAGE_libusbmuxd=y
CONFIG_PACKAGE_fcgi=y
CONFIG_PACKAGE_getdns=y
CONFIG_GETDNS_ENABLE_STUB_ONLY=y
CONFIG_PACKAGE_libblkid=y
CONFIG_PACKAGE_libblobmsg-json=y
CONFIG_PACKAGE_libcap=y
CONFIG_PACKAGE_libcares=y
CONFIG_PACKAGE_libcomerr=y
CONFIG_PACKAGE_libdb47=y
CONFIG_PACKAGE_libelf=y
CONFIG_PACKAGE_libevent2=y
CONFIG_PACKAGE_libexpat=y
CONFIG_PACKAGE_libext2fs=y
CONFIG_PACKAGE_libf2fs=y
CONFIG_PACKAGE_libffi=y
CONFIG_PACKAGE_libgdbm=y
CONFIG_PACKAGE_libgmp=y
CONFIG_PACKAGE_libjson-c=y
CONFIG_PACKAGE_libmnl=y
CONFIG_PACKAGE_libncurses=y
CONFIG_PACKAGE_libnetfilter-conntrack=y
CONFIG_PACKAGE_libnettle=y
CONFIG_PACKAGE_libnfnetlink=y
CONFIG_PACKAGE_libnl-tiny=y
CONFIG_PACKAGE_libpcap=y
CONFIG_PACKAGE_libpcre=y
CONFIG_PACKAGE_libreadline=y
CONFIG_PACKAGE_libsmartcols=y
CONFIG_PACKAGE_libss=y
CONFIG_PACKAGE_libubox=y
CONFIG_PACKAGE_libubus=y
CONFIG_PACKAGE_libuci=y
CONFIG_PACKAGE_libuclient=y
CONFIG_PACKAGE_libusb-1.0=y
CONFIG_PACKAGE_libuuid=y
CONFIG_PACKAGE_libxml2=y
CONFIG_RE2_SHARED=y
CONFIG_PACKAGE_terminfo=y
CONFIG_PACKAGE_zlib=y
CONFIG_LUCI_JSMIN=y
CONFIG_LUCI_CSSTIDY=y
CONFIG_PACKAGE_luci-lib-nixio_notls=y
CONFIG_POSTFIX_TLS=y
CONFIG_POSTFIX_SASL=y
CONFIG_POSTFIX_LDAP=y
CONFIG_POSTFIX_CDB=y
CONFIG_POSTFIX_SQLITE=y
CONFIG_POSTFIX_PCRE=y
CONFIG_PACKAGE_ip6tables=y
CONFIG_PACKAGE_iptables=y
CONFIG_PACKAGE_iptables-mod-conntrack-extra=y
CONFIG_PACKAGE_iptables-mod-ipopt=y
CONFIG_DNSDIST_OPENSSL=y
CONFIG_PACKAGE_stubby=y
CONFIG_PACKAGE_ncat=y
CONFIG_PACKAGE_ndiff=y
CONFIG_PACKAGE_nmap=y
CONFIG_PACKAGE_nping=y
CONFIG_OPENLDAP_DEBUG=y
CONFIG_PACKAGE_ip-full=y
CONFIG_PACKAGE_ip-tiny=y
CONFIG_PACKAGE_mwan3=y
CONFIG_PACKAGE_relayd=y
CONFIG_PACKAGE_openvpn-openssl=y
CONFIG_OPENVPN_openssl_ENABLE_LZ4=y
CONFIG_OPENVPN_openssl_ENABLE_X509_ALT_USERNAME=y
CONFIG_OPENVPN_openssl_ENABLE_MANAGEMENT=y
CONFIG_OPENVPN_openssl_ENABLE_FRAGMENT=y
CONFIG_OPENVPN_openssl_ENABLE_MULTIHOME=y
CONFIG_OPENVPN_openssl_ENABLE_PORT_SHARE=y
CONFIG_OPENVPN_openssl_ENABLE_DEF_AUTH=y
CONFIG_OPENVPN_openssl_ENABLE_PF=y
CONFIG_OPENVPN_openssl_ENABLE_IPROUTE2=y
CONFIG_OPENVPN_openssl_ENABLE_SMALL=y
CONFIG_PACKAGE_uqmi=y
CONFIG_PACKAGE_lighttpd=y
CONFIG_LIGHTTPD_SSL=y
CONFIG_PACKAGE_lighttpd-mod-access=y
CONFIG_PACKAGE_lighttpd-mod-cgi=y
CONFIG_PACKAGE_lighttpd-mod-expire=y
CONFIG_PACKAGE_lighttpd-mod-fastcgi=y
CONFIG_PACKAGE_lighttpd-mod-proxy=y
CONFIG_PACKAGE_ethtool=y
CONFIG_PACKAGE_hostapd-common=y
CONFIG_PACKAGE_ipset=y
CONFIG_PACKAGE_iw=y
CONFIG_PACKAGE_libipset=y
CONFIG_PACKAGE_netcat=y
CONFIG_PACKAGE_odhcp6c=y
CONFIG_PACKAGE_odhcp6c_ext_cer_id=0
CONFIG_PACKAGE_odhcpd-ipv6only=y
CONFIG_PACKAGE_odhcpd_ipv6only_ext_cer_id=0
CONFIG_PACKAGE_port-mirroring=y
CONFIG_PACKAGE_ppp=y
CONFIG_PACKAGE_ppp-mod-pppoe=y
CONFIG_PACKAGE_samba36-server=y
CONFIG_PACKAGE_SAMBA_MAX_DEBUG_LEVEL=-1
CONFIG_PACKAGE_tcpdump=y
CONFIG_PACKAGE_uclient-fetch=y
CONFIG_PACKAGE_wpa-cli=y
CONFIG_WPA_MSG_MIN_PRIORITY=3
CONFIG_DRIVER_11N_SUPPORT=y
CONFIG_DRIVER_11AC_SUPPORT=y
CONFIG_DRIVER_11W_SUPPORT=y
CONFIG_PACKAGE_wpad-openssl=y
CONFIG_PACKAGE_wwan=y
CONFIG_PACKAGE_uboot-envtools=y
CONFIG_PACKAGE_unzip=y
CONFIG_PACKAGE_blkid=y
CONFIG_PACKAGE_partx-utils=y
CONFIG_PACKAGE_vim=y
CONFIG_PACKAGE_e2fsprogs=y
CONFIG_PACKAGE_mkf2fs=y
CONFIG_PACKAGE_ntfs-3g=y
CONFIG_PACKAGE_NTFS-3G_HAS_PROBE=y
CONFIG_PACKAGE_bash=y
CONFIG_PACKAGE_minicom=y
CONFIG_PACKAGE_screen=y
CONFIG_PACKAGE_tmux=y
CONFIG_PACKAGE_usbmuxd=y
CONFIG_PACKAGE_jshn=y
CONFIG_PACKAGE_libjson-script=y
CONFIG_STRACE_NONE=y
CONFIG_PACKAGE_ubi-utils=y
CONFIG_PACKAGE_usb-modeswitch=y
CONFIG_OVERRIDE_PKGS=“openssl samba36 uqmi ustream-ssl”
reza@reza-ThinkPad-X260:/tmp$
Thanks again,
I’ve placed the DMESG output here on my webserver
http://mta.lethalnetworks.com/mv1000/dmesg.txt
I’ve identified my problem and found the right driver
root@GL-MV1000:/# lsusb -t
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M |
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=rtl8192eu, 480M
root@GL-MV1000:/# lsmod | grep 8192
8192eu 1273856 0
cfg80211 241664 4 8811au,8812au,8821cu,8192eu
root@GL-MV1000:/# find /lib/modules -name 8192eu.ko
/lib/modules/4.14.151/8192eu.ko
root@GL-MV1000:/# opkg search /lib/modules/4.14.151/8192eu.ko
kmod-8192eu - 4.14.151+2019-3-12-1
root@GL-MV1000:/#
Then I selected the following under make menuconfig
CONFIG_PACKAGE_kmod-8192eu=y
now the wlan0, 1 and 2 show up on my custom build.
i dont suppose you wish to share your files?
or have you tried building an Ubuntu with the latest Ubuntu-LTS version (22.04)
thanks.
also have you got the commands wroking for;
switch_system ubuntu
switch_system openwrt
