I’ve setup my AC1300 with my 4G and cable provider for Internet. The default route is set for cable, and the backup works great when the primary circuit goes down.
I’d like to get some kind of alert when this happens, and I’m struggling with how to approach this. Have any of you configured alerting for MWAN or OpenWRT? I can’t seem to find any doco to suggest a good solution.
Use the /etc/mwan3.user file to write a script to alert you. You can incorporate any alerting mechanism you want. You can even use Lua Slack hooks or just a simple email. If you have an SMS gateway, you can use that too.
Hello, I was wondering what the status of this enhancement is? I see it on the list to implement, but have yet to see a feature for it on my Spitz X3000. Thank you!!
