The current software version of 3.216 isn’t updating to 3.217.
I have tried this several times to no avail. And there is a disclosure here of issues on the routers.
What do I do about this?
You might want to make a manual update by going to
and download the latest version. Then, in the UI you can choose manual update and use the downloaded file.
Thank you so much. I did this suggested method and it worked. Everything is fine now
I’m glad it worked out.
