I’m encountering issue with the GL-XE 300 Puli router. I’m trying to upgrade the router with OpenWRT 22.03 on top of the GL standard binary using Uboot method. But I got some error regarding the NAND.
[ 0.383284] spi-nand spi0.1: unknown raw ID c851c851
[ 0.388530] spi-nand: probe of spi0.1 failed with error -524
[ 0.397810] spi-nor spi0.0: w25q128 (16384 Kbytes)
[ 0.402894] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.409537] OF: Bad cell count for /ahb/spi@1f000000/flash@0/partitions
[ 0.416389] OF: Bad cell count for /ahb/spi@1f000000/flash@0/partitions
[ 0.423997] Creating 5 MTD partitions on "spi0.0":
[ 0.429029] 0x000000000000-0x000000040000 : "u-boot"
[ 0.437226] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.443938] 0x000000050000-0x000000060000 : "art"
[ 0.451781] 0x000000060000-0x000000460000 : "kernel"
[ 0.458090] 0x000000460000-0x000001000000 : "nor_reserved"
From the above logs, it seems that NAND is not detected, and no partition is created inside it.
Device Information:
- Model: GL-XE300 Puli router
- Operating System: OpenWrt
I would appreciate any assistance or guidance on resolving this issue.
