Router: GL Inet 750M Travel AC Router
Client Net:
192.168.174.x
The Router makes a openVPN Connection to a VPN server.
The connection is working and a can ping an different client connected to VPN Server 192.168.173.x
Unfortunately the ping only works if I restart the firewall after starting the router. I do that with a script delayed after starting the router. But that doesn’t seem to be the correct solution to me.
When I try to connect client 1 to client 2 via VNC software on port 5900, this only works if I deactivate the firewall on client 1 router.
I need a rule how to allow traffic udp and tcp from 192.168.174.x through the VPN Connection 10.8.4.x.
