Hi, can you help me that where can I download shadowsocksr-libev-alt.ipk for Cortex A53
thank you very much.
help me please.
after install ipks:
opkg install libubox20210516_2021-05-16-b14c4688-2_aarch64_cortex-a53.ipk
opkg install libustream-openssl20201210_2020-12-10-68d09243-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-libev-config_3.3.5-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-libev-ss-redir_3.3.5-1_aarch64_cortex-a53.ipk
opkg install dns2socks_2.1-2_aarch64_cortex-a53.ipk
opkg install microsocks_1.0.2-2_aarch64_cortex-a53.ipk
opkg install pdnsd-alt_1.2.9b-par-2_aarch64_cortex-a53.ipk
opkg install tcping_0.3-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-rust-sslocal_1.11.1-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-rust-ssserver_1.11.1-1_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-check_2.5.6-9_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-local_2.5.6-9_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-redir_2.5.6-9_aarch64_cortex-a53.ipk
opkg install xray-core_1.4.2-1_aarch64_cortex-a53.ipk
opkg install kcptun-client_20210624-1_aarch64_cortex-a53.ipk
opkg install naiveproxy_91.0.4472.77-1-1_aarch64_cortex-a53.ipk
opkg install redsocks2_0.67-5_aarch64_cortex-a53.ipk
opkg install simple-obfs-client_0.0.5-1_aarch64_cortex-a53.ipk
opkg install simple-obfs-server_0.0.5-1_aarch64_cortex-a53.ipk
opkg install trojan_1.16.0-2_aarch64_cortex-a53.ipk
opkg install ipt2socks_1.1.3-2_aarch64_cortex-a53.ipk
opkg install luci-app-ssr-plus_184-9_all.ipk
opkg install luci-i18n-ssr-plus-zh-cn_184-9_all.ipk
opkg install bash_5.1-3_aarch64_cortex-a53.ipk
opkg install coreutils_8.30-2_aarch64_cortex-a53.ipk
opkg install coreutils-base64_8.30-2_aarch64_cortex-a53.ipk
opkg install kcptun-config_20201010-1_aarch64_cortex-a53.ipk
opkg install kcptun-client_20201010-1_aarch64_cortex-a53.ipk
opkg install luci-app-kcptun_1.5.2-1_all.ipk
opkg install luci-i18n-kcptun-zh-cn_1.5.2-1_all.ipk
opkg install v2ray-plugin_4.41.0-1_aarch64_cortex-a53.ipk
opkg install wget-ssl_1.21.1-1_aarch64_cortex-a53.ipk
the service-shadowsocksr plus+ display:
ShadowsocksR Plus+ NOT RUNNING
the log display:
2021-07-12 16:33:57: -----------end------------
2021-07-12 16:33:56: 禁止连接的域名加载完毕。
2021-07-12 16:33:56: 未启动主节点,禁止连接的域名正在加载。
2021-07-12 16:33:56: ----------start------------
2021-07-12 16:33:55: ssrplus redir tcp error.restart!
2021-07-12 16:33:25: -----------end------------
2021-07-12 16:33:19: Main node:ShadowsocksR 2 Threads Started!
2021-07-12 16:33:19: ----------start------------
2021-07-12 16:29:26: -----------end------------
2021-07-12 16:29:26: 禁止连接的域名加载完毕。
2021-07-12 16:29:26: 未启动主节点,禁止连接的域名正在加载。
2021-07-12 16:29:25: ----------start------------
error infomation is:
I’ve solved the problom. I will post the way later.
Install ShadowSocksR Plus+ on Gl-MV1000W
Firmware:
https://s3.us-east-2.amazonaws.com/download.gl-inet.com/firmware/mv1000/release/openwrt-mv1000-emmc-3.105.img
download ipk from:
ref https://uzbox.com/tech/remove-term-shadowsocksr-plus-shadowsocksr-plus.html, installation OK!
1.http://192.168.8.1/#/software, install:
luci
luci-base
luci-i18n-base-zh-cn
2.http://192.168.8.1/cgi-bin/luci, install:
opkg install shadowsocks-libev-ss-local_3.3.4-1_aarch64_cortex-a53.ipk
opkg install shadowsocks-libev-ss-redir_3.3.4-1_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-alt_2.5.6-6_aarch64_cortex-a53.ipk
opkg install pdnsd-alt_1.2.9b-par-a8e46ccba7b0fa2230d6c42ab6dcd92926f6c21d_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-ssr-local_2.5.6-6_aarch64_cortex-a53.ipk
opkg install tcpping_0.2-d890cc1bd8e3951390ceeff1ccb092a5d802850c_aarch64_cortex-a53.ipk
opkg install v2ray_4.23.4-1_aarch64_cortex-a53.ipk
opkg install shadowsocksr-libev-server_2.5.6-6_aarch64_cortex-a53.ipk
opkg install kcptun-client_20200409-1_aarch64_cortex-a53.ipk
opkg install luci-app-kcptun_1.4.5-1_all
opkg install luci-i18n-kcptun-zh-cn_1.4.5-1_all
opkg install luci-app-ssr-plus_178-6_all.ipk
opkg install luci-i18n-ssr-plus-zh-cn_178-6_all.ipk
3.ssh:
echo 0xDEADBEEF > /etc/config/google_fu_mode
4.reboot:
“ShadowSocksR Plus+”
display “ShadowsocksR Plus+ RUNNING”
能直接放一个固件吗 firmware image
我想直接复制一份你的XD
