Need Definitive Statement on 5G and Spitz X3000
To Mods
I have been chasing my tail trying to get my UK EE 5G SIM to work fully at 5G not 4G+ in my two Spitz X3000s. I now am seeing the problem on a Lebara/Vodafone UK SIM.
Many threads have bounced this about for well over a year on this and the OpenWRT forums as what is the cause/solution from duff SIMs, reflash firmware, use USB interface not PCIe etc. As yet I have seen no definitive statement from GL-inet/techs about it. Specifically is this a known bug in the Spitz X3000 or not?
If it isn't what is the solution and if it is what if the official workround and when will it be fixed?
I look forward to a positive reply.
Tom
Is the bug you're speaking of specifically regarding 5G or the combination of 5G and the carriers you have listed? My X3000 has no issues with 5G SA using T-Mobile in the US if that helps at all.
5G and these carriers
May I know if this SIM card insert in the phone, and is it attached 5G network?
Please email to support@gl-inet.com, to contact with the cellular support to check this issue.
SIM card was activated and used in a phone and attached to 5G network.
But not when in the X3000.
Hi @TunnylaneTom , for this issue, could you check the 5G frequency bands used by the phone?
  • For Android phone, you can find the cellular details, including the cell id, network type and frequency bands via some cellular analyzer app, e.g. Cellular-Z
  • For iPhone, dial *3001#12345#* to the Field testing mode to check the cellular info
Then try the following ways to see if you can get a 5G connection.
  1. Bind router to the same frequency bands using Band Masking feature
  2. Go to Tower Locking page, lock your sim card to the same cell tower as your mobile phone
  3. Execute this AT command from the admin panel->INTERNET->Cellular->Modem Management page and try it again: AT+QNWPREFCFG="mode_pref",NR5G
Thanks
Cathy
Problem seems to have resolved itself back in UK. Maybe because I used the X3000 and EE SIM in Holland who have great 5G infrstructure and it worked fine.
One query. When searching for towers/cells message comes up saying it can't find all towers while cellular interface is enabled. What does this mean?
Tom
I'm a little confused. Did the issue clear up while you were in the UK, or when you switched countries? I'm considering getting one of these x3000s for when I travel abroad from the US
Not an answer to your question but are these routers things that work globally or will you need a different modem for the US than the one for the EU?
It worked when I got back to UK
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
