Hi, all I need is a simple NAS solution which is needed to provide music via SMB/NTLMv2 to a music player (Bluesound).
So the device needs the following things:
- Gigabit Ethernet port
- USB 3.0 port (for a 256GB USB memory stick with the music files)
- standard IP stack (DHCP or static address, default gateway)
- SMB/NTLMv2 support
- configuration by Telnet/SSH or Web
Not needed:
- PoE (anyhow PoE in would be nice to eliminate the power supply)
- WiFi
Devices which seem interesting: Slate Plus (1300) or Beryl (1300), but what are the differences?
And what do you think, which should be the best box to buy?
