Hi!
Anyone own Mudi v2? I need you to run
ubus call system board
Please HIDE sensitive information.
I need this because I have some concerns about stability and security. In my case it is really important to be sure that everything OK
Hi!
Even without using the command, I can already tell you, that the device runs on an EOL branch of OpenWrt. Guess this is what you want to know?
Partly
The thing is I need full hardware+software detailing because of some internal plugins that I was developed for another OpenWRT. They interact with specific hardware calls so that is really important for me.
I know that that will not work from the box, but I need to know how much modifications I need to do and how stable hardware for it (will it handle it?)
It is exactly for development purposes, so that is the thing
root@GL-E750:~# ubus call system board
“kernel”: “5.10.176”,
“hostname”: “GL-E750”,
“system”: “Qualcomm Atheros QCA9533 ver 2 rev 0”,
“model”: “GL.iNet GL-E750”,
“board_name”: “glinet,gl-e750”,
“rootfs_type”: “squashfs”,
“release”: {
“distribution”: “OpenWrt”,
“version”: “22.03.4”,
“revision”: “r20123-38ccc47687”,
“target”: “ath79/nand”,
“description”: “OpenWrt 22.03.4 r20123-38ccc47687”
Thank you!
Bought!
What will you recommend to do now?
I need to make it as secure as possible. Please, don’t be afraid of technical details, I like administrating UNIX based systems:)
See photo here (Proton Drive)
I don’t get the question.
Secure against what?
