I am trying to set-up my router GL-AXT1800 as Wireguard client and facing Issue. Can anyone please help me in setting up the travel router. My Wiregurard server is setup behind the Optimum router and portforwarding is done on Opal router which is setup as wireguard server.
Issue Log:
Tue Oct 22 19:04:45 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Tue Oct 22 19:04:45 2024 daemon.notice netifd: Interface 'wgclient' is now down
Tue Oct 22 19:04:45 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Tue Oct 22 19:04:45 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Tue Oct 22 19:06:32 2024 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Tue Oct 22 19:06:32 2024 daemon.notice netifd: Interface 'wgclient' is now down
Tue Oct 22 19:06:32 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Tue Oct 22 19:06:32 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Configuration:
[Interface]
Address = 10.0.0.2/24
PrivateKey = removed for public view
DNS = 64.6.64.6
MTU = 1420
[Peer]
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = xxxxxx.glddns.com:51820 - changed for public view
PersistentKeepalive = 25
PublicKey = 7KNwl2kMWwwjE7j4Zsr6tSn2mPDshAjHbapH+As1+BI=
The port forwarding must be done on the Optimum router, not the Opal. Please read How to troubleshoot WireGuard as well and make sure you changed the network IP of one of the routers.
Hi - I did port forwarding on my optimum router. I used Opal behind the Optimum router and Used DDNS of Opal as IP in Optimum and Port 51820. I will lookinto documentation again and see if I missed any information.
Hi, have you been able to get it to work? I am having the same error.
My Setup:
Beryl Ax3000 = the VPN wont connect. With the same error as yours
Using AX1800 as the vpn server.
My ISP provided me a static IP, so i did a port forwarding on the router, assigning a port to the IP of the Flint Server.
So i reset mine and then used a different Internet provider and it worked perfectly. So not sure if it was the firmware, my Isp or my settings.. but its working now.
