Can someone tell me the name of IC U22
The router is GL-MT300N-V2. Thanks in advance.
I consult my colleague it’s ETA6020S2G.
Thank you, is there an alternative to this IC, or how to power this device without using the micro usb port?
you can also use MP62551/MP65151。
If you do not use the USB Type-A , you can remove U22
Removing the IC worked, thank you. The IC was burnt when I powered the device with 5.3v usb charger so beware.
