Hi GL.Inet,
Is there any possibility of supporting Netbird SD Wan, in the same way that you support,
Zerotier
Netscale
I am using the Beryl AX Travel Router and also the Mudi V2 Portable 4G LTE Router.
Thanks
Ciaran
Hi GL.Inet,
Zerotier
Netscale
Thanks
Ciaran
Hi, I collected it and will share to the PM to evaluate. Thanks.
I installed netbird successfully on a OpenWrt router.
The relevant package is available here.
I would really appreciate if you could integrate Netbird in your router software.
