Hello Everyone,
I am having issues with the OpenVPN setup on the GL-AR750. Netgear does not allow you to configure any OPVN setting server side and supplies 4 files to use with OPENVPN clients. I am able to succesfully use the VPN on my phone, Windows 10 OpenVPN client, however not able to to use the GL-AR750 OpenVPN client.
My Config is as follows.
client
dev tap
proto udp
sndbuf 393216
rcvbuf 393216
push “sndbuf 393216”
push “rcvbuf 393216”
remote removed.removedthiswebsiteforsecurity.com 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 4
Firmware of my GL-AR750 is 3.01, tried on the original firmware it shipped with 2.2~ and it didn’t work for either.
My GL-AR750 is connected directly to the modem for isolating the issue. I intend once its working to have it behind a netgear router.
This is the dump of my System LOG.
https://pastebin.com/jr6K2uhf
