Network Acceleration on GL-BE3600 (Slate 7) breaks WireGuard client forwarding and Tailscale direct connections (forces DERP)
Device: GL-BE3600 (Slate 7)
Summary: With Network Acceleration enabled, I saw two separate VPN-related problems that both went away once I disabled it. Posting in case this helps other users or the dev team.
Symptoms with Network Acceleration ON:
  • WireGuard client profile connects successfully, but TCP traffic from devices behind the Slate stalls/hangs (e.g. speed tests get stuck at “Contacting server”).
    • Tailscale repeatedly falls back to DERP instead of establishing a direct peer-to-peer connection.
  • Workarounds I tried first that did NOT fix it:
    • A firewall/nftables-style rule on the Slate intended to preserve Tailscale’s UDP source port (41641). After reboot/restart, tailscale ping still went via DERP(sfo).
      • An OPNsense outbound NAT static-port rule for the Slate’s LAN IP (to stop source-port rewriting). Also did not change the DERP behavior. tailscale netcheck still showed MappingVariesByDestIP: true.
    • What actually fixed it:
    • Disabling Network Acceleration on the Slate. After that:
      • WireGuard traffic stopped stalling immediately.
        • tailscale netcheck changed to MappingVariesByDestIP: false.
          • tailscale ping now shows a direct via <public-ip>:<port> path instead of via DERP(…).
            • Throughput through the VPN path is now ~250 Mbps down / ~86 Mbps up.
          • Why I’m posting: since a plain source-port/NAT fix didn’t resolve it, but toggling Network Acceleration did, it looks like the acceleration/offload path on the BE3600 may be interfering with both forwarded WireGuard client traffic and Tailscale’s NAT hole-punching. Would appreciate it if the team could take a look at whether Network Acceleration is compatible with WireGuard client mode + Tailscale, and whether this is expected behavior or a bug.
        • Happy to provide firmware version, full tailscale netcheck output, or logs if useful.
Thank you for the detailed report and testing.
Could you please let us know the current firmware version of your Slate 7?
If you are using v4.10.0 release , the behavior you described appears to be related to the same Network Acceleration issue we have reproduced previously.
Please refer to the following:
If you are using v4.9.x or another firmware version, could please reproduce the issue with Network Acceleration enabled and send us the output of tailscale netcheck , tailscale ping <peer> , and the exported System Log after the issue occurs.
Thank you again for your help and support.
How to export logs:
How to send private messages:
Hi I am using 4.10.0. Are you aware if this has been patched in latest FW
Thanks for confirming.
Firmware v4.10.1 is now available for the GL-BE3600 and includes an improvement for the Network Acceleration + VPN issue seen in v4.10.0.
Could you please upgrade to v4.10.1 , enable Network Acceleration again, and check whether the WireGuard traffic and Tailscale direct connection are working normally?
If the issue still persists after the update, please let us know and we can investigate further.
Thank you for your help with testing.
