GL.iNet AR-150 White with firmware 3.201; Network Mode: not Router but Access Point
While debugging something else, I ran Wireshark over night. In that twelve hours, my AR-150 sent 39 pings to 192.168.8.125. The ping happens not periodically but sometimes five minutes, sometimes one hour after the last ping. What is really a curiosity: My AR-150 is not within 192.168.8/24 at all. Any idea what might trigger that?
Access Point not Extender
MAC source is the GL.iNet
Nothing is attached to the Wi-Fi; the computer is just passively listening via a Switch with Port Mirroring enabled
You mean the computer who setup that Access Point? Mhm. Ages ago. Perhaps it got 8.125, yes. However, back then, I just changed the ‘mode’ via an Ethernet cable and then disconnected both. Rebooted quite often since then. Can’t you reproduce the issue? Until now, the longest time between two pings was exactly an hour.
