Network Port Rate of GL-MT3000
Hi everyopne,
I'm wondering how to change the gl-mt3000's Network Port Rate from duplex 100Mb to 1000Mb
Basically I'm in router mode and am limited to 100mb download and upload rate.
when I check the settings, it seems to be automatically set to 100 Mbps full duplex?
Thank you in advance.
Confirm that the peer device supports 1Gbps port and negotiates 1Gbps with other router.
  1. Please try to replace other network cables.
  2. Re-plug the network cable several times.
  3. Other devices are connected to MT3000 WAN. Regardless of whether it is an ISP modem, router, or client device, as long as it supports 1Gbps, you can see the current negotiation rate in the GL GUI after connecting. We only look at the negotiation rate to ensure that there is no hardware problem with this port.
