Tagor
November 28, 2024, 7:01pm
Scenario:
Laptop - > Slate AX tethering with iPhone as WireGuard Client --> Flint2 as WireGuardServer & Client /Cascading VPN enabled -> NetworkStorage on Flint2
At the moment Samba is only working with Devices connected with Lan directly on Flint 2
or Devices which are connected to the Wifi of Flint2.
So is it possible to acces the NetworkStorage of the Flint from Devices which are connected to the Slate ? // thx
admon
November 28, 2024, 8:23pm
2
I doubt this, tbh.
Samba should work fine using VPN - just make sure you use the VPN IP of the router instead of the 192.168.8.1 or whatever your routers IP is.
Tagor
November 28, 2024, 11:27pm
3
Maybe change here something ? I tried it with different and i am not sure if i need to put a port
in the end of the smb://yourVPNip:51820 - Link i put in the iphone ? //thx
admon
November 29, 2024, 6:03am
4
No. You don't need to change anything there.
Just try to connect via SMB to your router - just as you would do normally.
VPN-IP is your routers VPN IP. So your VPN network ending on .1
Tagor
November 29, 2024, 5:37pm
5
After an reboot of the iphone it works now. I guess i need to use sometime the "reject" Button byside the Drive in the Files-Folder of IOS.
THANKS
system
Closed
May 28, 2025, 5:37pm
6
