Network Storage paths broken after firmware update
Hello, I upgraded the firmware on my GL-AXT1800 router today and immediately following the update, the paths in my shared folders are no longer functioning. It appears that the names of the shared folders have been truncated at the position of the first space in the folder name. For example, a previously functioning shared folder was titled '(01) USB Drive Family Movies'. While it still appears with this name in the Network Storage portion of the Admin Panel, when I pull up the shared folder on another device it shows only '(01)'. I don't know what other details may be helpful to resolve this issue, so if I have omitted anything, please let me know.
Thanks for reviewing!
Could you please share some screenshots with us to clarify this issue?
Since I tested it on the Windows PC, it did not display the folder name when I add a network folder of the AXT1800, it displays the disk mounted path /disk1_part1:
Yes I can. I hope these suffice.
I have reproduced this issue, and submit it to R&D for inspection, thanks.
Thank you, Bruce.
