I have a new AR300M16-Ext ( FW 3.212 & AR71XX driver, etc.) and have set it up to use with my Android phone & Easytether. It works; that is, it appears to work.
I can connect via wi-fi from Android and/or Window clients – and all my connections show “Internet access”. However, my browser(s) & other online apps say I do not have an Internet connection!
What am I missing here? Thank you.
Try pinging 8.8.8.8 or opening https://1.1.1.1 to check if there is a DNS problem.
Thanks. I just did a reset – made sure everything was upgraded; & made sure my primary DNS was 1.1.1.1 (Cloudfare – which I use on all my devices).
Everything now works smoothly using my mini router with Easytether.
