after many many years with FritzBox i desidet to change my router to GL-MT6000. Yesterdayit arrived. Now i am sitting and reading the manual and try to connect to the 192.168.8.1 (over lan1) but unfortunately it is not possible, the given Wifi Gl-MT6000-xxx / 5G are not available.I already reseted the router to factory settings, nothing changed. the openwrt controll gui (192.168.1.1) is working. Can somebody support me with this issue or should i just send it back
Generally there is a layer of plastic film (foil?) outside the carton.
Probably due to an issue about the handling of goods in the Amazon warehouse. If you mind, you can contact Amazon for a replacement or email to us ([email protected]) to transfer to Amazon.
