Why?
I used that feature to be able to use my phone as an hotspot while having it on my lan without causing an infinite loop.
The option disappeared from the interface but it’s still in /etc/config/gl_block – how do I add/remove from that list?
Why?
You can create a profile for your client devices and set them up to block internet access in the Parental Control feature. This setting can be used in place of the old block WAN but allow LAN.
Sorry, this is a bug in upgrade. Please delete the file to remove old block.
