I saw that there was a new DominoPi firmware 1.3 that came out 3 weeks ago.
Could you please advertize it when some new firmware like this one is coming out ?
Also, I have notice that all “oldpackages” present in the 1.1 version are not there in 1.3.
Is there any reason ?
Fortunately, I used some of 1.1 to install them under 1.3, but I had to download them manually instead of relying to remote opkg.
alzhao
November 25, 2015, 9:25am
2
Hi Martinayotte, Firmware 1.3 is using openwrt CC1505. Software repo is upgraded and openwrt deleted “openpackages” by default.
What packages in “oldpackages” are needed by you. I will have a check.
Hi Alzhao,
i2c-tools along with its dependency libi2c.
Fortunately, using the one from 1.1 seems to work.
But maybe someothers would be interesting, like python-smbus, for which the old 1.1 still crashing.
alzhao
November 27, 2015, 11:35am
4
I see.
I can try to compile the “oldpackages” and upload them.
Thanks, Alzhao !
It will be appreciated by the community since maybe other packages are still helpful.
alzhao
November 30, 2015, 12:42pm
6
I am compiling the oldpackages, there are tens of packages failing to compile. Openwrt remove this by default because these packages are not actively maintained. I am trying to correct as many as possible.
