New firmware version 4.8 being released for beta testing
@raz1 @bill340 Very bad. Need to take the firmware down. SSH Still works though.
I am using IPv6 but the "Native" mode is diconnecting my VPN devices, Its only effecting them the rest of the devices are working perfectly, Nat6, Passthrough modes don't dissconect the VPN devices just the "Native" mode? Is there a way around this?
EDIT: Seems the issue lies with surfshark as they don't offer IPV6. So i have disabled it on the VPN devices :smiling_face:
So any help how to fix that via ssh?
Cannot access via ssh after factory reset also.
Can something be done through SSH?
Can you normally enter the firmware and load new firmware after a reset?
I don't know if I should reset it since you can't access it via SSH afterwards?
Resetting doesn't help. This problem has nothing to do with the configuration.
You can use Uboot to reinstall the previous beta version.
Subsequent snapshot versions will fix this problem. At that time, you can upgrade through SSH.
If you have access to ssh and the device has a network. You can run the following command to fix the problem of not being able to log in and then go ahead and upgrade.
wget https://fw.gl-inet.com/download/mt3000/login_Issues.sh && sh login_Issues.sh
If you don't have network, you can scp the gl-ui.tar to the device terminal.. And execute the commands:
tar -vxf gl-ui.tar
cd gl-ui
opkg install gl-sdk4-ui-core_git-2025.162.37381-9033056-1_aarch64_cortex-a53.ipk
opkg install gl-sdk4-ui-login_git-2025.160.13772-db857d5-1_aarch64_cortex-a53.ipk
gl-ui.tar (770 KB)
SSH 登录路由器 - GL.iNet Router Docs 4 --- SSH log in to the Router - GL.iNet Router Docs 4
Use WinSCP to modify files - GL.iNet Router Docs 4
Thank you! I was able to remote SSH via goodcloud and it fixed the issue.
In the latest beta for the MT-3000 Tailscale does not work with an exit node.
Devices have no internet access when exit node is active.
Any idea about that?
Why is Flint not getting updates anymore?
Last update 4.6.8 2024-10-17. I have 4.7.0 on it but it seems it was removed with zero word why. Why isnt this fixed with high priority?
4.7.0 has been withdrawn due to bugs; version 4.8.0 beta is available -> GL.iNet download center
Latest snap for Flint 2 is screwed up again, Luci is broken
Can you describe the issue you're encountering? Is it that you can't access Luci after installing it? If so, please run the following command to check the Luci configuration: cat /etc/config/uhttpd
I already rolled back, just try and access luci from your gui you will see the issue. Looks like a theme issue maybe by the error
I have upgraded the Latest snapshot on Flint. It works.
Hello!
Slate AX (GL-AXT1800) was successfully updated from version 4.6.11 to 4.8.0.
It seems like the settings were transferred well: WireGuard VPN, Encrypted DNS, DHCP range and repeater are good as well. The language settings are not fully synchronised though. For the first minute after update, I had a lot of 500 errors from the RPC endpoint, then a reboot and everything worked well (the client list was shown). After checking the VPN settings (I’m not sure if this is the trigger) but I get an errors on the clients list for the VPN and WLAN. On the home page, clients are not shown either. Rebooting doesn't help anymore.
errors from log
Fri Jun 13 10:00:03 2025 daemon.err eco[2210]: (gl-ngx-session:271) call ovpn-client.get_all_config_list fail with http code: 302
Fri Jun 13 10:00:03 2025 daemon.err eco[2210]: (gl-ngx-session:271) call wg-client.get_all_config_list fail with http code: 302
Fri Jun 13 10:00:11 2025  daemon.err eco[2210]: (gl-ngx-session:271) call ovpn-client.get_all_config_list fail with http code: 302
Fri Jun 13 10:00:11 2025  daemon.err eco[2210]: (gl-ngx-session:271) call wg-client.get_all_config_list fail with http code: 302
Fri Jun 13 10:05:09 2025 daemon.err eco[2210]: (gl-ngx-session:271) call cable.get_status fail with http code: 302
Fri Jun 13 10:28:20 2025 daemon.err eco[2210]: (gl-ngx-session:271) call clients.get_list fail with http code: 302
I encountered the exact same issue on my Flint (AX1800)
Updated from 4.7.0 to 4.8.0 (Settings were kept). Everything seemed to be working except the client list was blank.
Performed a factory reset and attempted to set everything up from scratch. All was good until I added an openvpn client config file (ProtonVPN) and turned it on. Client list then became blank again.
Had to revert back to 4.6.8 for now since 4.7 firmware was pulled and I didn't keep a copy
Trying to connect locally to a Beryl AX on the latest beta (0614) using the Glinet android app gives me a wrong password error again. Logging in via web or ssh works fine. Is it related to the previous password issue?
Tried reinstalling the app but it doesn't help.
Would greatly like to see Windscribe in the official list of VPN providers.
After the latest beta update 2025-06-14, commands with specific vpn group don't work anymore, all responses are executed from wan
ie: sudo -g ovpnclient1 xxx
works well with previous betas
Hibi have the problem.of not being able to login to my flint 2 can you advice on how to do it via goodcloud if you dont mind thanks
