Hello, just got a new Flint, I flashed later 4.1 FW, I configured VPN using NordVPN TCP, and UDP but it just stays as 0bytes out / in regardless.
Here is a log from TCP:
“Fri Feb 10 20:26:34 2023 user.notice ovpnclient-up: env value:SHLVL=2 PWD=/\nFri Feb 10 20:28:46 2023 user.notice ovpnclient-up: env value:SHLVL=2 PWD=/\nFri Feb 10 22:21:10 2023 daemon.notice netifd: Interface ‘ovpnclient’ is setting up now\nFri Feb 10 22:21:10 2023 daemon.warn ovpnclient[4156]: Cipher negotiation is disabled since neither P2MP client nor server mode is enabled\nFri Feb 10 22:21:10 2023 daemon.notice ovpnclient[4156]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]\nFri Feb 10 22:21:10 2023 daemon.notice ovpnclient[4156]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10\nFri Feb 10 22:21:10 2023 daemon.warn ovpnclient[4156]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts\nFri Feb 10 22:21:10 2023 daemon.warn ovpnclient[4156]: ******* WARNING *******: All encryption and authentication features disabled – All data will be tunnelled as clear text and will not be protected against man-in-the-middle changes. PLEASE DO RECONSIDER THIS CONFIGURATION!\nFri Feb 10 22:21:10 2023 daemon.notice ovpnclient[4156]: TUN/TAP device ovpnclient opened\nFri Feb 10 22:21:10 2023 daemon.notice ovpnclient[4156]: /etc/openvpn/scripts/ovpnclient-up ovpnclient 4 ovpnclient 1500 1500 init\nFri Feb 10 22:21:10 2023 user.notice ovpnclient-up: env value:daemon_log_redirect=0 script_type=up proto_1=udp daemon=0 SHLVL=1 dev_type=tun dev=ovpnclient remote_port_1=1194 daemon_start_time=1676060470 script_context=init verb=1 local_port_1=1194 link_mtu=1500 tun_mtu=1500 daemon_pid=4156 config=/tmp/ovpnclient/ovpnclient PWD=/lib/netifd/proto\nFri Feb 10 22:21:10 2023 daemon.notice netifd: Interface ‘ovpnclient’ is now up\nFri Feb 10 22:21:10 2023 daemon.notice netifd: Network device ‘ovpnclient’ link is up\nFri Feb 10 22:21:10 2023 kern.info kernel: [14636.984314] IPv6: ADDRCONF(NETDEV_UP): ovpnclient: link is not ready\nFri Feb 10 22:21:10 2023 daemon.warn ovpnclient[4156]: Could not determine IPv4/IPv6 protocol. Using AF_INET\nFri Feb 10 22:21:10 2023 daemon.notice ovpnclient[4156]: UDPv4 link local (bound): [AF_INET][undef]:1194\nFri Feb 10 22:21:10 2023 daemon.notice ovpnclient[4156]: UDPv4 link remote: [AF_UNSPEC]\nFri Feb 10 22:21:11 2023 user.notice firewall: Reloading firewall due to ifup of ovpnclient (ovpnclient)\n”
Here is a log from UDP
“Fri Feb 10 22:21:11 2023 user.notice firewall: Reloading firewall due to ifup of ovpnclient (ovpnclient)\nFri Feb 10 22:24:12 2023 daemon.notice netifd: Network device ‘ovpnclient’ link is down\nFri Feb 10 22:24:12 2023 daemon.notice netifd: ovpnclient (8410): Cannot find device "ovpnclient"\nFri Feb 10 22:24:12 2023 daemon.notice netifd: Interface ‘ovpnclient’ is now down\nFri Feb 10 22:24:24 2023 daemon.notice netifd: Interface ‘ovpnclient’ is setting up now\nFri Feb 10 22:24:24 2023 daemon.warn ovpnclient[9482]: Cipher negotiation is disabled since neither P2MP client nor server mode is enabled\nFri Feb 10 22:24:24 2023 daemon.notice ovpnclient[9482]: OpenVPN 2.5.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]\nFri Feb 10 22:24:24 2023 daemon.notice ovpnclient[9482]: library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10\nFri Feb 10 22:24:24 2023 daemon.warn ovpnclient[9482]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts\nFri Feb 10 22:24:24 2023 daemon.warn ovpnclient[9482]: ******* WARNING *******: All encryption and authentication features disabled – All data will be tunnelled as clear text and will not be protected against man-in-the-middle changes. PLEASE DO RECONSIDER THIS CONFIGURATION!\nFri Feb 10 22:24:24 2023 daemon.notice ovpnclient[9482]: TUN/TAP device ovpnclient opened\nFri Feb 10 22:24:24 2023 daemon.notice ovpnclient[9482]: /etc/openvpn/scripts/ovpnclient-up ovpnclient 4 ovpnclient 1500 1500 init\nFri Feb 10 22:24:24 2023 user.notice ovpnclient-up: env value:daemon_log_redirect=0 script_type=up proto_1=udp daemon=0 SHLVL=1 dev_type=tun dev=ovpnclient remote_port_1=1194 daemon_start_time=1676060664 script_context=init verb=1 local_port_1=1194 link_mtu=1500 tun_mtu=1500 daemon_pid=9482 config=/tmp/ovpnclient/ovpnclient PWD=/lib/netifd/proto\nFri Feb 10 22:24:24 2023 daemon.notice netifd: Interface ‘ovpnclient’ is now up\nFri Feb 10 22:24:24 2023 daemon.notice netifd: Network device ‘ovpnclient’ link is up\nFri Feb 10 22:24:24 2023 kern.info kernel: [14831.029103] IPv6: ADDRCONF(NETDEV_UP): ovpnclient: link is not ready\nFri Feb 10 22:24:24 2023 daemon.warn ovpnclient[9482]: Could not determine IPv4/IPv6 protocol. Using AF_INET\nFri Feb 10 22:24:24 2023 daemon.notice ovpnclient[9482]: UDPv4 link local (bound): [AF_INET][undef]:1194\nFri Feb 10 22:24:24 2023 daemon.notice ovpnclient[9482]: UDPv4 link remote: [AF_UNSPEC]\nFri Feb 10 22:24:25 2023 user.notice firewall: Reloading firewall due to ifup of ovpnclient (ovpnclient)\n”
As for Wireguard, trying to use TorGuard but it never establishes a connection, remaind “orange” Client is starting.
Some logs here:
“Fri Feb 10 22:26:50 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:26:56 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:01 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:06 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:11 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:16 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:21 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:26 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:31 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:36 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:42 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:47 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:47 2023 daemon.notice netifd: Interface ‘wgclient’ is now down\nFri Feb 10 22:27:47 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nFri Feb 10 22:27:53 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:27:58 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:28:03 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:28:08 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:28:14 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:28:19 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\n”
Another location:
“Fri Feb 10 22:34:35 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:34:40 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:34:45 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:34:51 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:34:56 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:01 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:06 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:12 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:17 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:22 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:27 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:32 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:37 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:43 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:48 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:53 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:59 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Feb 10 22:35:59 2023 daemon.notice netifd: Interface ‘wgclient’ is now down\nFri Feb 10 22:35:59 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nFri Feb 10 22:36:04 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\n”
Help is appreciated!
