Hi.
Is it somehow possible to enforce a change of identity (new node and IP address) while using Gli router with Tor firmware? I think this option is called ‘New identity’ as according to TOR terminology.
If yes, is it possible to make it while the switch is in the left position?
If not, it would be a great option to do so as a feature. For example, after holding the reset button for 5sec - the ‘identity’ is changing.
