Thanks for the link. I have had a look at that section and i have a basic understanding however what I wanted to know was, is there anything fun and extra you can do?
for example, can i create a torrent server with this or use it for media sharing by adding a HD to it and then people on that network can share the files?
Yeah, you can set up a VPN client or server. I use it as a proxy connection for hotels and even on airplanes (so I can share one purchased connection).
You can set up a Transmission client, which obviously has the torrent serving functionality, too.
It’s a mini linux, so the answer is pretty much anything.
As said above it’s pretty much a small linux, there is a repository of packages you can install where you’ll find tools, shells, programming languages etc.
You may run into issues (eg. I came across a package that only included a binary but not a shared library the binary depended on) but many things you would not normally run on a router work quite well.
I have not tried to set up a torrent server but I’ve experimented a bit with running an amule-client, unfortunately however it seems to lead to filesystem-corruption when there are many open files, but your mileage might vary.
If you only want to share media on the network that should be easy to do. I run mpd on it to play music over a very cheap usb-soundcard and simply use samba (that already comes installed) to watch movies on an attached USB-harddisk on my tablet.
How do you set up transmission server? i’ve already installed transmission-daemon, transmission-cli, and transmission-remote but transmission client still cannot connect to transmission server
do we have to change firewall setting, if yes how?
