New SSID on existing LAN interface
Hi, apologies for such a simple question, all I’ve found are answers to more complex questions.
All I’m hoping to achieve is adding another SSID to my existing LAN interface.
I will end up with:
Default_Main_Wifi
Default_New_Wifi
Within same subnet as the main wifi. No vlans or anything like that yet.
I went to LuCI > Network > Wireless, then Add to the 2.4ghz network card.
Flint2 & LuCI with latest firmware.
Shows as “Wireless is not associated”
Is set as ‘Access Point’ and lan interface is attached.
When searching my wifi networks I see HT_AP1 & HT_AP4 which I presume are from my two attempts at doing this.
Hi!
Could you please provide more details about the issue you encountered?
If you are having trouble creating a new SSID on the LAN, please follow these steps:
  1. First, reset the device by following this tutorial to clear any wireless settings configured via Luci and prevent future conflicts.
    Repair network or reset - GL.iNet Router Docs 4
  2. SSH into the router and add a new SSID to the LAN interface by running the following command:
# For the 5GHz SSID
uci del wireless.mt798612.disabled
uci set wireless.wifinet4=wifi-iface
uci set wireless.wifinet4.device='mt798612'
uci set wireless.wifinet4.mode='ap'
uci set wireless.wifinet4.ssid='GL Router-IoT-5G'
uci set wireless.wifinet4.encryption='psk2'
uci set wireless.wifinet4.key='goodlife'
uci set wireless.wifinet4.network='lan'
uci set wireless.wifinet4.ifname='rax2'
# For the 2.4GHz SSID
uci del wireless.mt798611.disabled
uci set wireless.wifinet5=wifi-iface
uci set wireless.wifinet5.device='mt798611'
uci set wireless.wifinet5.mode='ap'
uci set wireless.wifinet5.ssid='GL Router-IoT-2.4G'
uci set wireless.wifinet5.encryption='psk2'
uci set wireless.wifinet5.key='goodlife'
uci set wireless.wifinet5.network='lan'
uci set wireless.wifinet5.ifname='ra2'
#  Save the configuration and restart to take effect.
uci commit
reboot
Thanks for this, I will try SSH if I don’t find a GUI guide/method first. Much of what I found jumps straight into SSH which is fine, but would still prefer to use the interface someone took time to build.
I should be familiar with most of this from setting up my Pi VPN router years ago, but it has been a while.
What does mt798611 refer to that I need to delete and recreate it?
As mentioned, I want to create an additional 2.4 wifi access point in addition to the 2.4 and 5 main defaults and guests.
This additional 2.4 will be for most of my smarthome devices on vlans but that is later after I am more familiar with LuCI.
When I created the new SSID it just says “Wireless is not associated” and is broadcasting HT_AP instead of the SSID I named.
Since the stock firmware is built on the MTK SDK, compatibility between its Luci interface and the underlying closed-source wireless driver may be suboptimal.
We recommend configuring relevant options via SSH and UCI.
mt798611 is the identifier for the Wi-Fi chip.
The previous provided command just removes its disabled entry, thereby enabling it.
If you prefer configuring these through Luci, we recommend using the openwrt24 version, which uses open-source drivers and have good compatibility with Luci.
Download link:
Upgrade guide:
This worked, except now my 2 x 2.4 wifi networks share the same channel.
If i change one to say CH3 the others setting is also changed to 3 also. This is because they share the same radio right?
Yes, right.
