Just bought a 300N and very happy with it. Also looking to buy a 300A but am wondering if tor images will be out for these or even a new image for a 150. Current images are for last year.
Yes. I think so. Will update Tor image together.
Hello, have make a Tor Firmware for mt300a?
how can find it?
sorry still not available. I promise that I will provide next week.
Hello have you make a firmware?
Hi @lbpuma3,
As said, here is the tor firmware for MT300N: http://www.gl-inet.com/firmware/mt300n/tor/
For MT300A, http://www.gl-inet.com/firmware/mt300a/tor/
Usage:
- SSID is PORTAL, password is goodlife
- Both WiFi and LAN will use Tor connection
- The hardware switch is used to turn Tor on/off. If put on the left side, all connections are via Tor. If put on the right side, you will have Normal network.
- If you want to set up the router using webUI (luci), you need to put the switch on the right side (no Tor, normal network) and visit http://172.16.1.1. When the switch is on the left side, this page will not be accessible. We suggest that you set up the router first before using Tor.
Hi alzhao - for the AR150, do you recommend using the tor 1.2 (the release is a little old now), or get the normal 2.20 and installing tor manually?
I will research about getting the switch working/dual SSIDs etc, although if you have any links/help that is good too.
Thanks!
@nasna, maybe I can upgrade the firmware, using the same settings as MT300N and MT300A.
I don’t recommend installing Tor manually, unless you trust your skills.
In the new tor firmware, there is no Dual SSID anymore, which I think not good idea.
If you can upgrade the fw, that would be very good. Thank you.
I am comfortable enough installing tor to openwrt (there are many guides, right?) - but if there is anything special that needs to be done for this device… - I don’t know.
There is nothing special for this device. If you can do it by yourself, then it is the best way.
