Newb with Flint 2 - NordVPN on = NO web access
OK, I set it up properly, it connects to server, but I can't actually reach any websites with it ENABLED. I've searched around and see no obvious issue with my setup. Router works fine with it disabled but that's kind of the point (I need router VPN to work). Latest released firmware (4.7.7 I think). Please advise where to go from here
After configuring NordVPN and enabling it, is there a green light next to the VPN tab (indicating a successful connection to the VPN server)?
If it is yellow (meaning that the connection is in progress), and the 'Block Non-VPN Traffic' option is enabled or the 'Allow Access WAN' option is disabled, then all client traffic will be blocked at this point.
We also recommend that you upgrade the firmware to the latest 4.8.0 beta for further testing.
You can download it here and follow this tutorial to upgrade.
Thanks Will, upgrade to latest beta eliminated ALL my issues, thank you!!!!!!!!!
When will official 4.8 be released for flint 2?
If all goes well, formal firmware 4.8 for Flint 2 is expected to be released later in Q3.
