Hi there,
I am looking for a solution for flying where I only want to pay for one Wi-Fi connection but can use multiple devices. I came across the GL.iNet Shadow portable router and was wondering if it would suit my needs. Specifically:
Can it be easily configured to connect to the plane’s Wi-Fi using, for example, an iPhone as the initial connection? Is this fairly easy to do?
Can it run off a simple USB battery?
Thanks in advance for your advice!
